Misc Thread VI: Return of the Threadi
Re: Misc Thread VI: Return of the Threadi
Some Bozo wanted to require manual transmission cars to be in reverse to get the key out, eh? Reminds me how once a congressman proposed that they require seat belts on motorcycles!
Ha, my '63 Chevy had the key in the dashboard and you could start the car, pocket the key and drive off. The good old says when people had enough brains to operate dangerous equipment safely--and if they didn't, they paid for it. Seems fair enough!
Didn't VW Beetle have an auto clutch option? Seems I knew somebody had one and all you did was shift it. But that takes 90 p[ercent of the fun out of it. The intimacy is mainly in working the clutch because it was a special relationship that varied between cars and age of clutch etc. Anybody can move a lever, but it takes some skill to work a clutch properly.
So this DCT sounds like a Frankenstein's monster. Someone tried to make two partial manual transmissions, mate them with an extra clutch and pass it off as an automatic. So there must be a juice spinner somewhere in there?
So the traditional automatic with a juice spinner is at a stoplight. It is almost like driving with the brake on as the car wants to go and you are holding it back, so it is fighting against the stop.
I still expect the day when you go to check the oil and there is no latch but rather a sign that says, "Do Not Open. No User Serviceable Parts." Ninety percent of drivers couldn't care less about that as they have no idea what is under the hood nor want to know. They lease 2 years and turn it in. Bored of the stupid modern automotive styling that quick.
Obnoxious seems to be the styling cue for modern automotive design.
Get the key out? Out of what? My keys never leave my pocket.ClutchFork wrote: ↑Wed Jan 23, 2019 11:48 pm Some Bozo wanted to require manual transmission cars to be in reverse to get the key out, eh?
Took me a minute to get used to push button start, but now that I've had it for awhile I love it. The Mazda even has a walk away feature, whereby if I leave the car with the key in my pocket and don't actively lock it the car automatically locks. It's sometimes thwarted if I drive mom somewhere and she takes a bit longer to exit and I'm out of range before all the doors are closed. It gives a warning hoot of it's locking.Shadow wrote: ↑Thu Jan 24, 2019 1:45 pmGet the key out? Out of what? My keys never leave my pocket.ClutchFork wrote: ↑Wed Jan 23, 2019 11:48 pm Some Bozo wanted to require manual transmission cars to be in reverse to get the key out, eh?
Ford wasn't very successful with driver satisfaction with their dual-clutch automatics in the Fiesta and Focus. They designed them to eke out the highest fuel economy, but they didn't launch or shift very smoothly. Wet clutch DCTs are usually better at launch, because you can slip them and not have as much worries with clutch temperatures as you would with a dry clutch, but they aren't as fuel efficient. Adding a torque converter to launch like a "Normal" slushbox is probably better yet, but at that point, why not just give 'em a planetary-geared slushbox?
I've been driving the DCT equipped Focus on occassion (when mom doesn't need it) and don't find it to be egregiously difficult or annoying. It's possible that Ford got the bugs worked out in later iterations (mine is a 2017 after all) and I never drove the earlier ones with the high failure rates.Then again I'm used to driving my Mazda and I'm always a bit jiggly.
I'm still slightly leery about long-term durability, but the CPO warranty has helped allay some of those fears. I'd be curious about the moist clutch VWs.
tankinbeans wrote: ↑Fri Jan 25, 2019 2:38 am I've been driving the DCT equipped Focus on occassion (when mom doesn't need it) and don't find it to be egregiously difficult or annoying. It's possible that Ford got the bugs worked out in later iterations (mine is a 2017 after all) and I never drove the earlier ones with the high failure rates.Then again I'm used to driving my Mazda and I'm always a bit jiggly.
CPO warranty no wheres as good as new car warranty (let alone people's warranty), in my experience, fyi
what about Acura DCT w/ torque converter? supposedly very direct yet minimal shift shock; think it only uses torque converter on start-up and maybe low speeds, if that's possible. feat of engineering, iff eye say sew my self.Rope-Pusher wrote: ↑Thu Jan 24, 2019 9:20 pmFord wasn't very successful with driver satisfaction with their dual-clutch automatics in the Fiesta and Focus. They designed them to eke out the highest fuel economy, but they didn't launch or shift very smoothly. Wet clutch DCTs are usually better at launch, because you can slip them and not have as much worries with clutch temperatures as you would with a dry clutch, but they aren't as fuel efficient. Adding a torque converter to launch like a "Normal" slushbox is probably better yet, but at that point, why not just give 'em a planetary-geared slushbox?
A modern hydraulic clutch has no feel anyway, so that's easy enough. Maybe they could use force-feedback technology from arcade game joysticks to transmit synchronizer feel...hmm...IMBoring25 wrote: ↑Wed Jan 23, 2019 1:17 am You know, I wouldn't be thrilled with clutch-by-wire or shift-by-wire (for one thing, I've always appreciated a fully independent mechanical backup in the event the computer goes full HAL-9000, plus they probably wouldn't get the feel right), but I'm still a little disappointed that the shift to everything-by-wire and SMGs hasn't led to the realization that the difference between manual and automatic could suddenly be a footbox module, a shifter module, and commenting out a few lines of code. It could even be different driving modes of the same vehicle. The writing seems to be on the wall but increasing parts commonality and reducing certification burden and logistical footprint for offering the option could go a long way to keeping the "faith" alive a while longer.
Saab SensonicClutchFork wrote: ↑Wed Jan 23, 2019 11:48 pmDidn't VW Beetle have an auto clutch option? Seems I knew somebody had one and all you did was shift it.
The cousin living in my attic just called out of work because her 1 year old bit her tongue. The kid doesn't even care any more. f**k nuts. The only person who should be coddled in this house is me!
Why is small human close enough to bite cousin's tongue? That's a bit weird.
There's a name for people who French-kiss with children. They have even better name for people who get to 2nd base with them.tankinbeans wrote: ↑Fri Jan 25, 2019 10:26 pmWhy is small human close enough to bite cousin's tongue? That's a bit weird.
Another Effort to Overcome the Peritoneal Shortage of Automotive Technicians
"FCA, citing data from the U.S. Bureau of Labor Statistics, said there are approximately 750,000 auto technicians working in the U.S. But the industry will need to hire another 46,000 between 2019 and 2026 to meet increased demand."
https://www.autonews.com/nada-show/fca- ... 2-readmore
- Cars: 1986 Mazda RX-7 x2
lol, I was also confused at first.tankinbeans wrote: ↑Fri Jan 25, 2019 10:26 pmWhy is small human close enough to bite cousin's tongue? That's a bit weird.
1986 Mazda RX-7 base - Project car, ???, In pieces, turbo parts around.
Wow, I left work earlier than usual today, just after 5 pm, and the roads were deserted. It was weird to not see any cars on the freeway for miles and miles. Eye bleef that a lot of people went home early to get a jump on clearing the snow, or to avoid a nasty afternoon rush-hour.
