Got my new (used) wheels today!
Re: Got my new (used) wheels today!
Any dedicated winter tire will always be better than any all season tire on ice and snow.
Paul, the a cture you posted are NOT winter tires. Zero siping.
- Cars: 2001 S10 2.2L manual
They came up under a google search for snow tires. Anyway, the snow tires I used to run 30+ years ago were very chunky treaded like that, and they were not very good on ice, but then maybe no tire would be good on ice in the light rear end weight pickup truck. Anyway, it looks like there are some nice winter tire options out there, but to do the most good need 4 of them regardless of which wheels drive the vehicle. Not likely to do it, too much storage space and hassle for the mild winters we get here. Maybe worth it in Minnesota. If I did it, I would not use the old wheels, they are pretty rotten, would get more wheels like I just got.AHTOXA wrote:Any dedicated winter tire will always be better than any all season tire on ice and snow.
Paul, the [pi]cture you posted are NOT winter tires. Zero siping.
Detroit has decent winters as did Chicago. Texas winters are what I would call 'mild'.
This.InlinePaul wrote:But Googling snow tires shows they are far more advanced today.
As mentioned, there's siping. There's also different rubber compounds. And, in my recommendation, there are metal studs that dig into ice like claws. Around here they're only legal during the winter.
You are right, very nice tire selections for winter, not sure the legality of metal studs in Michigan.
Here she is in all here police wheel glory with shiny center caps:
The center caps really help a lot.
I looked it up. In Michigan, studded tires are permitted but only with rubber studs. So lame. I would probably end up running winter tires all year, though I might keep two sets of wheels and tires so I could put on fresh ones before winter and finish wearing out semi-worn ones in the summer. (That's approximately what I do anyway, except I have to pull the studs out.)
Yeah my wife did not like them until I put the chrome caps on.theholycow wrote:The center caps really help a lot.
Newer tread is the way to go for winter for sure. You have a great idea with the two sets of wheels. I'm not planning on going that route, but it is smart.I looked it up. In Michigan, studded tires are permitted but only with rubber studs. So lame. I would probably end up running winter tires all year, though I might keep two sets of wheels and tires so I could put on fresh ones before winter and finish wearing out semi-worn ones in the summer. (That's approximately what I do anyway, except I have to pull the studs out.)
- Cars: '13 ES 350; '07 Altima
i'll put it to you this way (billy mays here!!): my firestone winterforce tires are studdable, but i don't run them with studs. from what i've read, studdable tires aren't designed to do well on ice without studs, while studless tires usually are designed to do okay on ice without studs. these tires without studs handle ice way better than any all-season tire i've used. they're not perfect by any means, but they're plenty good for my needs. if i lived where i had to drive over sheets of ice all day, i'd probably stud them or find a better tire for ice.
So should I do this
Here is why I wanted to get rid of the wheels (besides their being ugly, cheezy, fake fancy):
Pretty serious rot, eh?
that would be awesome, 8 or 10 foot bed in a ranger FTWInlinePaul wrote: So should I do this:
my only question: which set of wheels gets the power??
Front axle gets power, else have to go around it to second axle. Bad on turns I suspect. They have this on some motorhomes (rare), second axle is called a "tag axle" I guess because it tags along for the ride?potownrob wrote: my only question: which set of wheels gets the power??
- watkins
Goodyear Wrangers, if Im not mistaken. Definitely not snow tires at all.InlinePaul wrote:How ancient? The image in my mind of snow tires is from about 30 years ago. Something more like this:potownrob wrote:huh?! how do you figure that?? my ancient (according to tony) firestone snow tires perform lightyears better on ice than any highly rated all-season tires i've run, despite the firestones not being highly rated for ice. they are actually amazing, and a hoot to drive on snow and ice.
Those aren't going to be any better on ice, maybe worse that regular tires. But Googling snow tires shows they are far more advanced today.
What for are they? Look like the kind of tires I would get in the 1970s, like tractor tires.watkins wrote:Goodyear Wrangers, if Im not mistaken. Definitely not snow tires at all.
- watkins
Mild off road tires. Factory tires on higher trim Jeep Wranglers.
Guess I never knew what a snow tire was unless they were styled like off road tires back in the 1970s? No wonder they didn't work well on ice.watkins wrote:Mild off road tires. Factory tires on higher trim Jeep Wranglers.
