Tip for the day by pacroozer
Developing a perfect launch 101
REmember that the gas pedal is long unlike the clutch pedal.
if you press on the gas with your whole foot you lose range of motion.
however, if you press on the very bottom of the pedal with your toe you have that extra space in between the pedal and the floor to work your see saw with, unlike how you would if you pressed on the top half. This is also crucial for shifting without slip, and for downshifting without slip.
"Powered by Honda"
- eaglecatcher
- Cars: '90 300ZXTT 5MT
Ok, rev matches are smoother and less wear, especially at high revs.GSR wrote:my argument is that its better to slip while the gas is falling. as opposed to slipping while the gas is revved. doesn't make sense to me to rev match a downshift.
You want to downshift from 4th at 2000 rpm, to 2nd at 3200rpm. With a no-gas, you are using the clutch to raise the rpm, and therefore, you are slipping it to smooth it out, or if you drop the clutch, it will jerk the drivetrain, and wear that out.
With a rev matched downshift, take the same scenario, but, instead of using the clutch to raise the rpm, us the gas pedal, blip the gas, and then as you are ready to let the clutch out, you can let it out very fast, because the engine is spinning at the right speed for the next gear.
If you don't understand that, then I don't know if you should even drive a stick.
Z1 Intake
Z1 2.5" Test pipes
HKS 65mm Hi-Power Exhaust
AMS Short Shifter
SZ Subframe Spacers
HKS Vein Pressure Converter
DDM Tuning 6000k HIDs
Z1 2.5" Test pipes
AMS Short Shifter
SZ Subframe Spacers
Though of course:GSR wrote:my argument is that its better to slip while the gas is falling. as opposed to slipping while the gas is revved. doesn't make sense to me to rev match a downshift.
If I can launch in 1 second at 2500 RPM, and it takes 2.5 seconds to launch at 1250 RPM, technically it's better to rev (it IS less wear).
Just an example, I don't have a tach installed right now, so I can't tell my revs...
When you rev-match, the gas is falling as you release the cutch through the FP. You've blipped and completely let go of the gas when you rev-match.GSR wrote:my argument is that its better to slip while the gas is falling. as opposed to slipping while the gas is revved. doesn't make sense to me to rev match a downshift.
- jomotopia
exactly, thank you mikey.Hatchman wrote:When you rev-match, the gas is falling as you release the cutch through the FP. You've blipped and completely let go of the gas when you rev-match.GSR wrote:my argument is that its better to slip while the gas is falling. as opposed to slipping while the gas is revved. doesn't make sense to me to rev match a downshift.
now everybody stop feeding the troll.
- snikro
But, if you launch at lower RPM's, wouldn't it still be ok because, even though you would have to slip longer, the difference between engine speed and wheel speed (wheel=0 obviously) would be much less, so it would be ok to slip the clutch for longer because each second of slip would cause less wear. This is what I heard the CarTalk guys say on the radio- that when you normally launch your car, "it should be on the virge of stalling." This is correct reasoning, no?StrangeWill wrote:Though of course:GSR wrote:my argument is that its better to slip while the gas is falling. as opposed to slipping while the gas is revved. doesn't make sense to me to rev match a downshift.
'73 Schwinn Suburban
'85 Honda Aero 50 (Sold)
