Stupid Auto Repair Ideas
ClutchFork
Cars: 2008 Fusion 2.3L manual
Post by ClutchFork »
Another forum I am on has a thread titled "Stupid Thread Ideas." Lots of fun. Maybe something like this will work here. so to start.
Gorilla tape to fabricate a head gasket in a pinch. How much torque on the head bolts to make this one work?
Re: Stupid Auto Repair Ideas
ClutchFork wrote: Mon Apr 05, 2021 11:04 pm Another forum I am on has a thread titled "Stupid Thread Ideas." Lots of fun. Maybe something like this will work here. so to start.
In a pinch you can just keep running it with the leaky head gasket and pour in coolant or Earl or whatever it starts to run low on.
Speaking of stupid ideas, I would enjoy being a fly on the wall at Honda when they discuss how they had to recall a butt-load of cars because gasoline harmed the fuel pumps.
https://www.autoweek.com/news/industry- ... mp-recall/
ClutchFork
When I was 18 years old i had a beater Ford. The power steering pump died, think the bearing seized or something. We yanked the pump, and plugged the lines, then found an old alternator in my friends garage that had a good bearing, bolted it in where the PS pump had been and stretched the v-belt to it so the real alternator would work. Pop the hood and you saw two alternators, one a dummy for the pulley. Oh, the steering wheel was distorting as I did parking maneuvers in that car. PS gearing is not the same as manual steering gearing. The stupid part was not replacing the PS pump. Needed a gorilla to steer it after that.
ClutchFork
Rope-Pusher wrote: Fri Apr 09, 2021 12:38 pm
Wow, you just got me to thinking of another great idea. We can use that technique to get rid of used antifreeze, but instead of a head gasket leak we can just pour is slowly into the intake while keeping the rpms up around 4000 and blow that stuff off. EPA won't let you pour it in the gutter, but never said you cant suck it through the intake. It magically disappears.
Cars: '17 CX-5 GT
Post by potownrob »
seams like a goed whey two keep de tail gators at bae
Cars: '17 CX-5 GT
Post by potownrob »
ClutchFork wrote: Sun Apr 11, 2021 12:38 am
doughn't fur get too cheque de blinker flue id to :!: :shock:
Summon on a Canadian comedy show once came up with the idea of allowing toxic waste fluids to slowly drip out of a tanker truck as it drove across the country, such that in no one place was enough fluid released that it violated any statutes.
ClutchFork
Rope-Pusher wrote: Sun Apr 11, 2021 11:41 am Summon on a Canadian comedy show once came up with the idea of allowing toxic waste fluids to slowly drip out of a tanker truck as it drove across the country, such that in no one place was enough fluid released that it violated any statutes.
Har har har. Kind of like the old road draft tubes to ventilate crankcases before someone invented the PCV system.
They used to say dilution is the solution to pollution.
noob5,000,000
Cars: 1986 Mazda RX-7 x2
Post by noob5,000,000 »
When my friend somehow blew a hole in his Jetta's transmission, I stuck a square of beer can over the hole with a bunch of RTV. It probably would have held up but he gave the car to a charity shortly after.
ClutchFork
noob5,000,000 wrote: Tue Apr 13, 2021 1:26 am When my friend somehow blew a hole in his Jetta's transmission,
Now there is an interesting story. I heard some FWDs if you spin the tire like mad trying to get unstuck there is a pin or something holding the gear to the shaft and the pin will let go from the spinning and puncture the case. Perhaps that is what happened.
Once when I was an irresponsible young punk I went to Colorado with a friend who was also irresponsible. Driving in the mountains and on Sunday the one of the brakes was having problems, we pulled the drum and the pin that holds the shoe to the backing plate was broken and got between the pad and the drum or some thing like that. There were no part stores open in this small mountain town, so we took a nail, beat one end flat like the end of the pin (or more likely just bent the end over) and mounted the shoe to the backing plate with it. Lasted the rest of the trip, so maybe wasn't so stupid after all.
ClutchFork wrote: Tue Apr 13, 2021 1:41 am
Yes, especially when a vehicle is new, and the parts aren't burnished, one, or two, might seize a pinion gear to the shaft in the differential housing (The spinning flings all the oil out of the diff and the pinion gear interface goes dry). Then the shaft will be spinning instead of sitting still and it shears the pin retaining it and then it starts to inch its way out of the differential, machining a slot in the transmission case until it ventilates. Then the fluid all runs out and someone purchases a boat for the owner of a local transmission shop.
I took my Mom's Ford Pimple Wagon to the Midas Muffler Shop because the exhaust pipe was imitating Swiss Cheese. They called me into the service bay to show me the pin retaining the rear drum brake shoe had failed and the shoe was starting to wear unevenly. They didn't even mention the exhaust system. I told them that the brake shoe retainer pin was something I could fix and asked them "But what about the exhaust system?". I was really surprised that they heard the brake shoe making a funny noise when the exhaust was leaking noise. I was maybe even more surprised that they didn't call me back there to show me what pipes were "Holy" and to discuss how much a new exhaust system was going to cost.
Hay Noob - wear ya bean? Is that "Hot Chick" still living across the street from you?
Rope-Pusher wrote: Tue Apr 13, 2021 12:40 pm Hay Noob - wear ya bean? Is that "Hot Chick" still living across the street from you?
Holy shit! It's been over a year
noob5,000,000
Uhh, I don't understand the reference :oops: .
noob5,000,000 wrote: Thu Apr 15, 2021 9:23 pm
Your neighbor Adam - he has a last name, right? ...and it sounds like "Hot Chick"?
