EricTheCarGuy teaches you to drive stick
- bk7794
- Cars: 00 Civic (Stock)
Re: EricTheCarGuy teaches you to drive stick
His clutch change on that car was pretty cool to see. Definitely a quality youtube repair man.
The Clutch should be thees far up off the downstop when eet begins to grab - Hamid Carguy
Wait at least 24 hours for the paint on the shift knob to dry - Hamid Carguy
...and then this idiot comes driving toward me down the one-way street - Hamid Carguy
So I was driving this semi, hauling a load of watermelon to Alaska, when the road turned to a sheet of ice - Hamid Carguy
I don't care what you are driving, 10 speeds is too many gears - Hamid Carguy
When the tips of the gear teeth try to mesh together, it is called "Tooth Butt" - Hamid Carguy
When the engine rpm starts to drop, hesitate releasing the clutch for a second or it will tend to grab abruptly - Hamid Carguy
I thought I was changing the radio station, but I was too drunk to know that it was an old Chrysler Push-Button transmission and instead I shifted it into Reverse at 70 mph - Hamid Carguy
......a see-saw motion, letting up on the clutch pedal as you press down on the accelerator pedal - Hamid Carguy
Here is the church and here is the steeple,..... - Hamid Carguy
The shift knob was small and uncomfortable to grasp - Hamid Carguy
Possibility of sex: 0 - Hamid Carguy
1st gear, it's all right,
2nd gear, I lean right,
3rd gear, hold on tight,.... - Hamid Carguy
