2013 Accord - 2.4L Direct Injection/3.5L V6
- Cars: VW GTI Mk. V
I didn't get very much seat time with the 2.4L Direct Injection model as of yet. Still, I have test driven both the 2.4L and the 3.5L (V6) so far. The direct injection 2.4L is a very nice and quiet car, but the V6 keeps the same refinement while adding a throaty exhaust note and much better torque and horsepower.
-2013 Accord Coupe V6-
My first experience with the 2013 Accord was with the 2.4L Direct Injection model, which is a fantastically refined car, if a bit boring for auto enthusiasts like me. I spent a total of 2 days with it, and believe that it offers a very BMW-esque ride comfort and handling. I like BMWs, but I find them to be so refined that the driving experience becomes somewhat diluted for the senses. The Accord 2.4L was the same; very quiet, smooth, and goes around town without much commotion. In my opinnion, all of this- when combined, is exactly what the intended demographic of this car are looking for.
However, next came the Accord V6 coupe. This is now one of my favourite modern Hondas. It does not have the fuel economy of the 2.4L direct injection engine, but it makes great power and torque, sounds great, and still takes 87 octane fuel only! When you drive this car, you will instantly be reminded of how smooth and refined the 3.5L Honda V6 mill is. It really is a great engine, and now makes 278 hp at 6200 RPM, and 252 lb-ft of torque at 4900 RPM. For comparison, this is almost 100 hp more than the 2.4L direct injection four cylinder, which puts out 185 hp at 6400 RPM and 181 lb-ft of torque at 3900 RPM. You will notice the difference despite the heavier weight of the V6!
Cosmetically, I am not such a big fan of the Hyundai Genesis style tail lights on the 2013 Accord sedan. On the other hand, the coupe looks very nice from the rear, with more slender tail lights than before. The headlights on both sedan and coupe are very similar, but it looks like Honda is using a narrower headlight on the coupe to help make the car look sportier when compared to the coupe. The hood on the coupe also appears to be different altogether.
Still, for many, the most exciting feature of this car is the added convenience and safety features. Both Accord sedan and coupe features FCW (Forward Collision Warning), LDW (Lane Departure Warning), and Lanewatch Blind Spot Display on the higher trim levels.
FCW will flash an amber warning light from the base of the windshield, along with audbile alerts when the computer determines that you are approaching the car in front of you too quickly. In the time I spent with the system, it does not, however, intervene your braking or throttle inputs. For aggressive drivers that cut lanes really close to the car in front of them, the system will warn you of your dangerous driving;) LDW is a lane watch system that will beep when your vehicle departs your current lane of choice. It is not a perfect system at this time, but is relatively good. You have the option to turn off LDW at will, but not FCW. There is a dedicated button in the area to the left of the steering wheel to switch ON/OFF LDW. Now, perhaps the most important technology fitted to these cars is the Lanewatch feature. There is a camera mounted to the bottom of the passenger side mirror. The image from the camera shows you what's in your blind spot. and can be shown on the Navi screen all the time if you wish. Otherwise, the image from the blind spot automatically shows up on the navi screen when you signal to the right to change lanes. It's a very handy feature that is excellent to use, and undoubtedly improves safety in all conditions.
A mainly infotainment-oriented feature called Hondalink is now also available on these cars, allowing you to stream music using apps like Pandora from your cell phone directly into the car's speaker system. I am quite certain that Hondalink has other features too, but I have not had the opportunity to test them all out yet.
Overall, I really liked the Accord V6. It has alot of features for the money, but is still built as a great handling car at its core. The car is a bit big though, but it does feel very luxurious both inside and out, which should automatically set higher standards for Acura interiors in the future too!
-More pictures-
View from the Driver's Seat
The Speedometer
Two Screens (The lower one is touch enabled)
Sleek Coupe Lines
2013 Accord Sedan - 2.4L Direct Injection
Night shot from Nov. 18 - Dual LED headlights on each front corner
-More pictures-
The Speedometer
Sleek Coupe Lines
GTI Mk5 6MT -| Dieselgeek | VF Engineering | O.Z. | Wavetrac | Forge | AWE | H&R | Öhlins | ITG
- bk7794
- Cars: 00 Civic (Stock)
Re: 2013 Accord 2.4L Direct Injection
Make sure to see how the engine sounds, like is it loud as all the other DI engines.
bk7794 wrote:Make sure to see how the engine sounds, like is it loud as all the other DI engines.
Why do you say that DI engines are loud? My car is DI and it doesn't sound any louder than a car with port injection.
I agree with Shadow. You wouldn't know mine was GDI by looking at it, there are no decals on the body unlike other companies who offer the same technology. The only think different, that I can tell, is a slight clickity clack sound from the injectors when the bonnet is open.Shadow wrote:bk7794 wrote:Make sure to see how the engine sounds, like is it loud as all the other DI engines.
It's not a continuously variable sewing machine is it? I would be sad.
I think I've only seen a couple of these in the wild. They certainly look much better than the previous generation's hippopotamus. Much sleeker, although the rump looks a little...um...pronounced.
As far as I can tell, all port injectors make clicking sounds too. If anything, I think direct injectors are more quiet than port injectors simply because of their respective locations in or on the engine.tankinbeans wrote: The only think different, that I can tell, is a slight clickity clack sound from the injectors when the bonnet is open.
- bk7794
KIA& Hyundai engines are really loud atleast on videos. I just watched a video on the 2.4l and it wasn't too bad.
this here VW 2.5 litre I-5 sounds somewhat like an exotic or at least a luxury V6 when opened up. once i get used to the throttle (or it gets used to me) then i'll be grinning all day.
That 2.5 has been described as half of a Lamborghini V10.
http://www.golfmk6.com/forums/showthrea ... 1f&t=41875
Don't know aboot that but it is pretty decently torquey for a little econobox engine, isn't it?
- bk7794
The exhaust did sound pretty neat when I watched a review of it.
Probably half a Lambo engine that's been detuned. If I recall correctly, it's rated 170 horse with 177 torques. I'd have to ask my friend though. I do know that you can get up to decent speeds without hitting 2k rpm.theholycow wrote:That 2.5 has been described as half of a Lamborghini V10.
VW does own, or have a big share of Lambo.
On a side note, I didn't realize Fiat owned Maserati and Ferrari.
wait, i didn't get another damn econobox, did i?!?!? i thought the jetta was a luxury car (it sounds like one at least)theholycow wrote:That 2.5 has been described as half of a Lamborghini V10.
Supposedly, it was deconted for this generation. Seems nice enough though. I've never been in the S model though, so maybe that one is worse.potownrob wrote:wait, i didn't get another damn econobox, did i?!?!? i thought the jetta was a luxury car (it sounds like one at least)theholycow wrote:That 2.5 has been described as half of a Lamborghini V10.
they definitely cut some corners compared to the mkV but its not terrible and nothing seems to affect actual driving (other than maybe the rear beam suspension and simplified steering system). To me it looks way nicer inside and out. The S has the 2.0 and doesn't have cruise control and a few other things and no leatherette, but its otherwise similar. You have to step up to the GLI to get the more luxurious jnterior.tankinbeans wrote: Supposedly, it was deconted for this generation. Seems nice enough though. I've never been in the S model though, so maybe that one is worse.
The steering system and suspension were great strengths of the MKV. What did they do to it exactly?potownrob wrote:nothing seems to affect actual driving (other than maybe the rear beam suspension and simplified steering system).
Not having leatherette wouldn't bother me. I won't pay extra for vinyl.
My mom said or was funny because people used to last more for cloth over vinyl, but now they pay more for vinyl (with a different name).
