humming sound when engaging in first gear.
JelloShot
Post by JelloShot » Thu Oct 18, 2012 1:25 pm
Hi folks,
I notice a humming sound when engaging the clutch in first gear. More specifically, when I am holding the clutch at the friction point. It does not happen every time though.
The car has 36 thousand miles and stock clutch. There's no clutch slippage, and the car drives fine.
Help would be much appreciated.
thanks
Re: humming sound when engaging in first gear.
Post by bk7794 » Fri Oct 19, 2012 11:57 pm
JelloShot wrote:Hi folks,
thanks
Possibly a pilot bearing, input shaft bearing, or the throwout bearing. I get that occasionally...then again I have 301k on my car...
2000 Honda Civic EX 5 Speed
Volvo S60R 6 Speed - Sold
JelloShot
Post by JelloShot » Sat Oct 20, 2012 10:34 pm
The mechanic at the dealership said it could be leaky dual mass flywheel.
It appears that this is common issue with VW TDI and GTI transmission. It would be fixed under warranty.
thanks for the reply
Post by Squint » Sat Oct 27, 2012 7:03 pm
JelloShot wrote:The mechanic at the dealership said it could be leaky dual mass flywheel.
Get it fixed/Did that fix it?
