Page 1 of 2
Upshifting Technique Question
Posted: Fri Aug 31, 2018 12:01 pm
by DDB91
Hi,
I've been trying to smooth out upshifts however there's so much information online and I want to clarify a few things.
Most information says to release throttle completely when upshifting however when causally driving I feel rushed to change gear to catch the rpms coming down. This is random, depending on cold engine and air con etc and the slow rate being unpredictable causes the rpm to be too low sometimes and not others making muscle memory side difficult.
I've been trialing easing off the gas rather than releasing completely and then keeping it where the rpm would need to be. This way I can take as long as needed to shift and it's always smooth. I'm worried this causes more wear though? Is the wear less because the rpm is matched or does having a slight touch on the gas still affect anything else.
Thanks
Re: Upshifting Technique Question
Posted: Fri Aug 31, 2018 3:25 pm
by tankinbeans
I would say that as long as you're not keeping the clutch partially engaged for an extended period of time you're fine. Every car is different and mine tends to pulse the throttle up slightly during upshifting maneuvers.
Posted: Sat Sep 01, 2018 1:35 pm
by DDB91
Thanks for the input and nope the clutch comes straight up smoothly so all good then. How do you mean your throttle pulses?
Posted: Sat Sep 01, 2018 1:43 pm
by tankinbeans
When I first disengage the clutch the revs increase briefly and then I can them on the way down.
Posted: Sat Sep 01, 2018 3:30 pm
by DDB91
Oh I understand now. Thanks for the input before, I was just concerned about causing some wear and tear unknowingly . With what you said seems its not the case as long as I'm not half engaging the clutch for a unnecessary amount of time while holding the revs at the right spot.
Posted: Sat Sep 01, 2018 5:40 pm
by tankinbeans
You're very welcome. It's normal too worry about clutch wear, but it seems that too often people worry unnecessarily. My intro thread is hilarious to read looking back on it. I was concerned about everything. I've gotten to the point where I just go with the flow.
Out of curiosity, what do you drive?
Posted: Sun Sep 02, 2018 5:50 am
by DDB91
Haha yeah worrying about everything sounds very familiar ^^. This is just a corsa but I got it new hoping for a cheap run around but couldn't naturally drive it eco.
What is it you're driving?
Posted: Sun Sep 02, 2018 9:40 am
by tankinbeans
I have a Mazda6. It's a pretty sweet ride and I like driving it tons.
Posted: Tue Sep 11, 2018 4:03 pm
DDB91 wrote: ↑Fri Aug 31, 2018 12:01 pmIs the wear less because the rpm is matched or does having a slight touch on the gas still affect anything else.
Indeed, the wear is less because the RPM is matched.
With practice this will likely cease to be an issue, as you will probably shift more quickly and learn to overlap your actions instead of separating them into distinct "one-two-three" type procedures with time wasted between steps. Most of all it will cease to be an issue because you will be comfortable and you will cease worrying!
Besides holding the accelerator pedal for steady RPM, you can accomplish the same thing by stepping on the accelerator pedal just before the clutch really begins to grab, instead of waiting until after. I mean, come on, you're trying to accelerate, right? Make your right foot as eager as a 7-year-old on Christmas morning! Jump the gun a little. I don't mean a whole second; I mean a fraction of a second before...so instead of your left foot reaching the top before your right foot presses on its pedal, both feet are in motion simultaneously. Like learning the rest of this stuff, doing this will be clunky at first but you'll get better. This will likely come naturally to you after lots of practice, just as overlapping steps and moving the shift lever more quickly will.
Posted: Tue Sep 11, 2018 10:29 pm
by ClutchFork
For fun sometime you can on a hard run, not even take your foot off the gas while at lightning speed, hitting the clutch and yanking it into second and releasing the clutch. I recommend this on the 1-2 shift as you are far less likely to have a missed shift. I tend to do this on freeway ramps when someone thinks they will jump ahead and zip in front of me. Why? Fun I guess, but also if they have a stink bomb that I don't want to ride behind and breathe their exhaust.
Posted: Wed Sep 12, 2018 6:38 am
by potownrob
Posted: Thu Sep 13, 2018 7:17 am
by DDB91
Haha thanks all and funnily enough it's more going into a cruise that I was having the issue, when actually accelerating it was natural without any problems. I'll give it a try
Posted: Mon Sep 02, 2019 11:55 am
by monkeyhunk
I float out clutch in with most of my shifts on my Jeep. Just seems to be a habit I've unconsciously gotten into from driving a big truck more than my personal vehicle. It does seem to be pretty smooth most of the time though.
Posted: Mon Nov 25, 2019 10:05 am
by Shedrick
How can that be smooth? Your technique must be good. haha
Posted: Mon Nov 25, 2019 2:04 pm
by IMBoring25
Ultimate smoothness comes from the throttle. The clutch can only mask imperfect throttle technique.
Floating the disengagement isn't that hard. You just have to find the throttle position where the engine isn't putting any load through the drivetrain, and if there's resistance when you gently push the shifter you're not there yet. Floating the re-engagement takes a lot more precision and familiarity with the vehicle, especially if you don't want to damage it.
