0 = Ntankinbeans wrote:Now I want a 0 gear!
1>2 shift
Re: 1>2 shift
But wouldn't we also need to consider Schrödinger's Cat:theholycow wrote:There's not enough room on shift knob diagrams for "10", so 10th gear is labeled 0. The really interesting bit, though, is that when you wind out zeroth gear you end up at a stop and can engage first again. Einstein's theory of relativity predicts it, and the gear ratio is a multiple of the Planck constant, resulting in a ratio system that is best diagrammed as a Möbius strip:tankinbeans wrote:Now I want a 0 gear!
These are notoriously difficult to manufacture because of a difficult material to make. The necessary iron ion needs spooky action at a distance to bind with deuterium before it can become the material that can be used for such gears. The necessary quantum weirdness is just too expensive.
http://www.uh.edu/engines/epi347.htm
Re: 1>2 shift
Zeroth gear IS Schrödinger's gear. If you're not sure whether you're stopped or moving, shift into it and find out.InlinePaul wrote:But wouldn't we also need to consider Schrödinger's Cat:
Re: 1>2 shift
But.. are we ever really stopped, man? I mean, man, do we like, ever really know about the earth moving, man?theholycow wrote:Zeroth gear IS Schrödinger's gear. If you're not sure whether you're stopped or moving, shift into it and find out.InlinePaul wrote:But wouldn't we also need to consider Schrödinger's Cat:
Re: 1>2 shift
Squint wrote:But.. are we ever really stopped, man? I mean, man, do we like, ever really know about the earth moving, man?
Re: 1>2 shift
***scratches beard***Squint wrote:But.. are we ever really stopped, man? I mean, man, do we like, ever really know about the earth moving, man?theholycow wrote:Zeroth gear IS Schrödinger's gear. If you're not sure whether you're stopped or moving, shift into it and find out.InlinePaul wrote:But wouldn't we also need to consider Schrödinger's Cat:
I know a few people I'd like to be on the business end of an Earth that screeched to a halt, just make sure you grab hold of something tightly because that could get awkward.
Re: 1>2 shift
tankinbeans wrote:I know a few people I'd like to be on the business end of an Earth that screeched to a halt, just make sure you grab hold of something tightly because that could get awkward.
Things are getting a little rough on the bridge Captain. I recommend we come down out of warp speed.
Re: 1>2 shift
We can't stop. It's too dangerous. We've got to slow down first.Squint wrote:But.. are we ever really stopped, man? I mean, man, do we like, ever really know about the earth moving, man?theholycow wrote:Zeroth gear IS Schrödinger's gear. If you're not sure whether you're stopped or moving, shift into it and find out.InlinePaul wrote:But wouldn't we also need to consider Schrödinger's Cat:
Re: 1>2 shift
In order to make the transition between 1st to 2nd gear, it's best to apply a small amount of throttle simultaneously whilst slowly releasing the clutch which will allow you to not only have a smoother shift but also a much quicker transition! Just don't give too much gas.
Re: 1>2 shift
RESOLVED!!!
I had my clutch bled at the dealer against the tech's recommendations a few months ago and I haven't ha the problem since!!! So happy. I can smoothly transition into any gear and driving is much more pleasurable now. Shifting is more predictable and I know when it is going to grab unlike before. I just hope I didn't have premature clutch wear.
I still have the whirring sound when cold that goes away after a mile or so. I read this is the throwout bearing and that it is normal and don't think I am going to persue this noise.
2011 WRX Sedan
Re: 1>2 shift
In daze of oldechardcore wrote:RESOLVED!!!
when nights were cold,
and rubbers weren't invented,......
A clearance was maintained between the tips of the fingers of the clutch cover diaphragm spring and the face of the clutch release bearing. Initial application of foot to the clutch release pedal closed this gap.
In these modern times, there is no gap - the face of the bearing is in constant contact with the spring tips. Sometimes, if the preload is low, or the bearing lube is thick, or......., then the bearing face can spin at a different rate than the clutch cover and a noise is borne. It seems like some effort could have been taken to make the face of the bearing positively engage with the spring tips so there would never be a potential for this relative motion, but being the only OEM to request this feature would be like being a salmon swimming upstream during the spring thaw rush.
Re: 1>2 shift
Rope's poetry is wonderful. Can we get a published book at some point?Rope-Pusher wrote:In daze of oldechardcore wrote:RESOLVED!!!
Re: 1>2 shift
Had to come back here and post an update.echardcore wrote:RESOLVED!!!
The issue wasn't actually resolved. One day this tarted happening.
[youtube]https://www.youtube.com/watch?v=GH4JP0LxbWg[/youtube]
Ignore the socks.
I was in shock but at the same time I was happy because now I had some proof.
Long story short...
The dealer goodwilled a bunch of clutch parts.
"TRANS BELL HOUSING REMOVED TRANS CLUTCH RELEASE BEARING WORN INTO PRESSURE PLATE RELEASE BEARING LOCKING UP REPLACED RELEASE BEARING & CLUTCH PRESSURE PLATE REASSEMBLE ROAD TEST OK AT THIS TIME"
I also had them swap the disc since they were in there. The old disc looked fine and had plenty of meat.
The car is night and day. So much more fun to drive. I can actually now slip the clutch properly. It feels a little lighter. No whirring. No noises at all.
2011 WRX Sedan
Re: 1>2 shift
Ficksetechardcore wrote:Had to come back here and post an update.echardcore wrote:RESOLVED!!!
Ignore the socks.
Long story short...
