Advice needed - new manual driver with abrupt/grabby clutch
- Cars: Peugeot 307 2L
Re: Advice needed - new manual driver with abrupt/grabby clu
If you pause long enough at the upper part of friction point without moving your throttle position, and on a flat ground, your clutch will eventually become fully engaged in its course to holy matrimony.
ok, let's say it is fully engaged at the upper part of friction point, and it makes no sense if we add gas at this moment before we fully release the clutch, right?Reverence wrote:If you pause long enough at the upper part of friction point without moving your throttle position, and on a flat ground, your clutch will eventually become fully engaged in its course to holy matrimony.
zaf wrote: ok, let's say it is fully engaged at the upper part of friction point, and it makes no sense if we add gas at this moment before we fully release the clutch, right?
it makes sense to add a little gas just before full engagement of clutch (as it begins to grab), so that you don't get engine brake at full engagement. This is what see saw'ing is about.
You should always add gas, a little at a time, before you are fully engaged, or she will be asking you "What's that horrible smell?" for the rest of your life.
It really depends on the situation. However, if you had to wait a while for the clutch to sync up, adding significant gas without letting your foot off the clutch pedal more will result in the clutch slipping again since it has just barely enough holding power at that position for the previous amount of torque the engine was producing.zaf wrote:ok, let's say it is fully engaged at the upper part of friction point, and it makes no sense if we add gas at this moment before we fully release the clutch, right?Reverence wrote:If you pause long enough at the upper part of friction point without moving your throttle position, and on a flat ground, your clutch will eventually become fully engaged in its course to holy matrimony.
Have you seen this?
http://www.howstuffworks.com/clutch.htm
On pages two and three are interactive demos that can help understand the clutch better.
So the amount of gas I need to add is not constant, should depend on the position of the clutch, right?theholycow wrote:It really depends on the situation. However, if you had to wait a while for the clutch to sync up, adding significant gas without letting your foot off the clutch pedal more will result in the clutch slipping again since it has just barely enough holding power at that position for the previous amount of torque the engine was producing.zaf wrote:ok, let's say it is fully engaged at the upper part of friction point, and it makes no sense if we add gas at this moment before we fully release the clutch, right?Reverence wrote:If you pause long enough at the upper part of friction point without moving your throttle position, and on a flat ground, your clutch will eventually become fully engaged in its course to holy matrimony.
Have you seen this?
I think I have rev hang in my car, so do I suppose to add gas later than normally when it should?
most likely, yes, but like THC said (and its true of almost everything while driving manual) it depends on your circumstances. there are a thousand different combinations for each of launching, upshifting and downshifting. when someone says on here you should do x when y happens, almost every single time x and y are completely different than another situation. we dont know your circumstances you just kinda have to figure it out on your own.zaf wrote:I think I have rev hang in my car, so do I suppose to add gas later than normally when it should?
Thanks for your reply.LHOswald wrote:most likely, yes, but like THC said (and its true of almost everything while driving manual) it depends on your circumstances. there are a thousand different combinations for each of launching, upshifting and downshifting. when someone says on here you should do x when y happens, almost every single time x and y are completely different than another situation. we dont know your circumstances you just kinda have to figure it out on your own.zaf wrote:I think I have rev hang in my car, so do I suppose to add gas later than normally when it should?
I got to practice more
If female drivers started adding gas, a little at a time, before they were fully engaged, that would put me off for the rest of my life.Rope-Pusher wrote:You should always add gas, a little at a time, before you are fully engaged, or she will be asking you "What's that horrible smell?" for the rest of your life.
Very few things in manual transmission driving are constant...everything depends on everything else. We can give you advice for how to adjust based on what you feel, but we can't tell you what you need ahead of time.zaf wrote:So the amount of gas I need to add is not constant, should depend on the position of the clutch, right?
Rev hang may indeed mean you have to add gas later.
What car do you drive?
It is a 2002 hyundai elantra glstheholycow wrote:Very few things in manual transmission driving are constant...everything depends on everything else. We can give you advice for how to adjust based on what you feel, but we can't tell you what you need ahead of time.zaf wrote:So the amount of gas I need to add is not constant, should depend on the position of the clutch, right?
It is even weird that I have more chance to have a jerky motion in 3-4 than 2-3, and I am sure the rpm is higher than what is needed in either case.
- RITmusic2k
- Cars: 2004 BMW 330i ZHP
If your rpms are higher than needed, then you'll definitely feel a jerk - the only way to eliminate a jerk is for the engine revs to be matched or very close to the transmission speed before you even begin to release the clutch. If for a certain gear and vehicle speed the engine needs to turn at 2,000rpms, then being at 2,500rpms will feel about exactly as jerky as being at 1,500rpms (but it'll be in the opposite direction). Releasing the clutch more slowly will ease the jerkiness, but the only way to be very smooth is to get the engine closer to the target speed; once you've done that you can release the clutch pedal as quickly as you can and the car still wouldn't jerk.
RITmusic2k wrote:If your rpms are higher than needed, then you'll definitely feel a jerk - the only way to eliminate a jerk is for the engine revs to be matched or very close to the transmission speed before you even begin to release the clutch. If for a certain gear and vehicle speed the engine needs to turn at 2,000rpms, then being at 2,500rpms will feel about exactly as jerky as being at 1,500rpms (but it'll be in the opposite direction). Releasing the clutch more slowly will ease the jerkiness, but the only way to be very smooth is to get the engine closer to the target speed; once you've done that you can release the clutch pedal as quickly as you can and the car still wouldn't jerk.
I know that, but the rpm drops slowly, I do not to wait
The only options you have left are to let the clutch out slowly or accept shift shock. With slow-dropping RPM the only way to finish your shift quickly and resume accelerating quickly is to accept shift shock.zaf wrote:the rpm drops slowly, I do not to wait
theholycow wrote:The only options you have left are to let the clutch out slowly or accept shift shock. With slow-dropping RPM the only way to finish your shift quickly and resume accelerating quickly is to accept shift shock.zaf wrote:the rpm drops slowly, I do not to wait
Dose this kind of rev hang happen individually or will all hyundai elantra of that model have that?
