zaf wrote:Dose this kind of rev hang happen individually or will all hyundai elantra of that model have that?
If the car is working properly then all of the same-equipped same year same model will have it. Differently equipped models (mainly those with different engine or transmission) may not.
Also, rev hang may depend on the exact conditions. For example, my VW's rev hang went away when the car was cold, first thing in the morning. At low RPM it didn't seem to hang at all. So, if you ask another driver about their car and they drive differently or are in a different climate or some other condition is different they may not experience rev hang.
I hate rev hang, haha
I was surprised that VW rabbit which is a quite sporty hatchback also has rev hang
A lot of cars do. Most people probably don't notice it though. We(manual drivers) rely much more on throttle input, so we'd notice much quicker than the average Joe. My mom's Avalon has a funky gas pedal. I pushed it to the floor and the tach needle didn't even move for a good second or two. She doesn't notice it and neither does anyone else. She thinks I'm crazy.
Throttle lag: Whatever you do with the accelerator, it takes a portion of a second or even a couple seconds to happen. Most DBW cars are likely to have this as the computer measures your input, decides what to do with it, makes sure you still want it, and then operates the throttle.
Torque converter lag (in an automatic only, of course): You step on the accelerator and the engine speeds up but the vehicle doesn't go for a portion of a second or even a couple seconds. People install high-stall torque converters to get this so they can spool up some power. I find it quite annoying, I depend on the vehicle going as soon as I get on the gas, especially when jumping out into traffic.
Rev hang: When you take you foot off the accelerator, it sticks at that exact RPM for longer than your normal throttle lag...usually way, way longer. Basically it just acts like you never took your foot off the accelerator and never slows until you load it down so hard (usually by upshifting) that it can't hold that speed. Acts like a stuck throttle.
Heavy flywheel / engine deceleration slowed by computer: When you take your foot off the accelerator the RPM drops slowly (but it does drop, even if very slowly). If the effect is 100% consistent then it's probably a heavy flywheel, but if it gets worse and better (randomly or depending on conditions) then it's the computer. Really, even a very heavy flywheel (53 pounds in my 4.1 liter V6) doesn't affect your rate of engine deceleration much.
What makes us happy: When you step on the accelerator the engine begins accelerating; when you remove your foot from the accelerator the engine begins decelerating and decelerates at whatever rate the flywheel allows.
theholycow wrote:Throttle lag: Whatever you do with the accelerator, it takes a portion of a second or even a couple seconds to happen. Most DBW cars are likely to have this as the computer measures your input, decides what to do with it, makes sure you still want it, and then operates the throttle.
On most cars, throttle lag can be tuned out completely, or at least so much that it would be imperceptible to even the most discriminating driver. So I don't think it's an issue of time, meaning that it just takes too long for the PCM to translate pedal position into throttle opening, it's more of the way the vehicle is tuned from the factory in the first place. I prefer a very sensitive throttle, but unfortunately they don't all come that way from the factory.
Shadow wrote:On most cars, throttle lag can be tuned out completely, or at least so much that it would be imperceptible to even the most discriminating driver.
Indeed, that's what I've heard from people who've had tunes. I assume that the lag is added on purpose to smooth out accelerator pedal input and make sure that the driver really intended to step on it.
the only throttle lag I get in my car is when idling in gear and stepping on it. Above idling, response is quasi immediate. Wonder why... anything to do with DFCO?
For those of you that have a Volkswagen car with the 2.0T engine and have rev hang or throttle sticking issues, you may want to check out or sign the petition that is online.
