Synchromesh and rev-hang
Re: Synchromesh and rev-hang
Just shift it as you see fit and let DOG sort out which ones were good and which weren't.
- fa22raptorf22
- Cars: 2004 SSM Acura RSX
Inertiatheholycow wrote:It's not going to go up from gravity. Power's the only way it goes up.fa22raptorf22 wrote:Nahh, you don't want to let the clutch up under power. Thats bad anyway you look at it. Its fine to catch it while the rpm is going up....but not going up under power.
400rpm off is a botched rev match by my standards.
Inertia keeps it at the same speed. Inertia won't accelerate your engine.fa22raptorf22 wrote:Inertiatheholycow wrote:It's not going to go up from gravity. Power's the only way it goes up.fa22raptorf22 wrote:Nahh, you don't want to let the clutch up under power. Thats bad anyway you look at it. Its fine to catch it while the rpm is going up....but not going up under power.
More off topics posts... should be moved to rants and raves.
While we're at it: isn't inertia an undefined concept from which momentum stems; momentum being resistance to change (which could mean that something that is constantly changing is simply resistant to further change).
how the hell is that off topic?
Because gizmo is overly literal about thread topics.
- fa22raptorf22
What happens when you are going up a hill and let off the gas? Do you suddenly halt? Or do you keep moving up the hill?theholycow wrote:Inertia keeps it at the same speed. Inertia won't accelerate your engine.
Same with engine rpm, if you blipped the throttle, even when you let off of it, it will still increase for a second till it settles out and goes back down.
Also, someone above said that their rpm drops too quick to DC an upshift.
Thats bs because a DC'ed upshift takes exactly the same amount of time as an SC.
All you have to do is pull the shifter out of gear without the clutch, and then clutch into the next gear. Problem solved.
Your speed immediately begins slowing. If you're accelerating up the hill and stomp your clutch, your car doesn't keep accelerating from inertia.fa22raptorf22 wrote:What happens when you are going up a hill and let off the gas? Do you suddenly halt? Or do you keep moving up the hill?
- fa22raptorf22
Remember, that even though this is true, the rpm keeps going up but at a decreasing rate.paul34 wrote:Force = mass*acceleration
Acceleration = Force/Mass
No throttle, no fuel, no force (if you're going uphill and no one is pushing you), so no acceleration. Maybe you are refering to dashpot-type behavior where your foot might be off the throttle, but the computer or a mechanical device keeps the throttle open.
Say your rpm is defined by f(x).
f(x) is increasing, but f'(x) is decreasing, till f'(x) becomes 0, at which point the rpm stops going up and comes down.
fa22raptorf22 wrote:Say your rpm is defined by f(x).
- fa22raptorf22
^^ What???
Do we not understand that something can still increase whilst its rate decreases?
nope. i only got up to geometry
- fa22raptorf22
:facepalm:LHOswald wrote:nope. i only got up to geometry
You better be kidding.
Anyway, my point to all this is that rev hang is the result of one or two things.
1) You lifted the throttle but the ecu takes a second to respond and stop adding fuel.
--This is more common with drive-by-wires because you do not have direct linkage to the throttle plate.
2) You lifted the throttle and the engine did respond near instantly, but the rpm continues to increase for a second because you added enough throttle to bring it to a certain rpm, but let up early...So there was enough power to start making the rpm increase, but then it kept increasing, but slowed down as it did.
The rev hang or the vw throttle sticking is really bad on new generation Volkswagen cars that have a manual transmission. It is so bad that clutches are wearing out very early. It can also cause accidents in certain situations etc.
There is a petition that you can sign if you have one of the cars with the issue. The petition also has some good info about rev hang and there are links to videos.
Volkswagen 2.0T petition can be found here.
http://www.ipetitions.com/petition/peti ... -rpm-hang/
