noob5,000,000's 1986 Mazda RX7, the clean one from Texas
noob5,000,000
Cars: 1986 Mazda RX-7 x2
Re: noob5,000,000's 1986 Mazda RX7, the clean one from Texas
Post by noob5,000,000 » Sun Feb 24, 2013 10:40 pm
theholycow wrote:
noob5,000,000 wrote:- DTSS (rear steer) eliminator bushings
wat
:lol:
From what I understand, there's a bushing in each of the rear hubs that is designed to deform a certain way during turns to add toe to the rear wheels, thus using the rear wheels to 'steer'. I've heard that when functioning correctly the system is kind of unpredictable, and when the bushings are old and torn up (as most are by now) it gets worse. It's a pretty common mod to replace the specialized bushings with conventional ones.
1986 Mazda RX-7 base - Project car, nearly driveable in n/a form, gathering parts for turbo swap
Post by theholycow » Sun Feb 24, 2013 10:45 pm
I was aware of the system but didn't realize that it produces unpredictable results. In that case, carry on. Image
Post by Rope-Pusher » Sun Feb 24, 2013 11:33 pm
theholycow wrote:I was aware of the system but didn't realize that it produces unpredictable results. In that case, carrion. Image
You DO know they charge EXTRA$$$ for carrion these days, right?
noob5,000,000
Post by noob5,000,000 » Sun Mar 03, 2013 2:43 am
I set up my 20 ton press and already pressed out one of the rear hubs.
These bearings could have done 100k more miles, easily! :lol:
Really, the balls (lol) and races don't look too bad, but the fact that the metal dust cover is all rusted and ruffled, and was detached before pressing began, is a little disconcerting.
1974Alfa5spd
Post by 1974Alfa5spd » Sun Mar 03, 2013 2:46 am
Only 100k? Those could've been million-milers easy.
noob5,000,000
Post by noob5,000,000 » Sun Mar 03, 2013 3:45 am
Blast! I'm can't find an appropriate tool to push the bearing out the rest of the way. The base of my 54mm socket worked for the first 3/4" or so, but then the shoulder of the socket contacts the bearing carrier and can't push anymore.
Post by theholycow » Sun Mar 03, 2013 7:38 am
Y U NO CLEAN RUSTY CRUD?
Did you end up figuring out a tool? Sounds like a slightly different socket, maybe a modified one, or a piece of black pipe might do.
Post by Rope-Pusher » Sun Mar 03, 2013 10:22 am
noob5,000,000 wrote:I set up my 20 ton press and already pressed out one of the rear hubs.
eye yam pressed!
noob5,000,000
Post by noob5,000,000 » Sun Mar 03, 2013 8:25 pm
theholycow wrote:Y U NO CLEAN RUSTY CRUD?
Yeah, I ended up finding a long 36mm socket that worked like a charm. I'll have to post a picture of the giant c-clip you have to remove to get the bearing out.
Post by Rope-Pusher » Sun Mar 03, 2013 8:43 pm
noob5,000,000 wrote: Yeah, I ended up finding a long 36mm sockeye salmon that worked like a clam.
I'll have to post a giant Sea clip you have to remove to get the herring out.
Fickset
noob5,000,000
Post by noob5,000,000 » Sun Mar 03, 2013 9:18 pm
noob5,000,000
Post by noob5,000,000 » Mon Mar 04, 2013 2:53 am
noob5,000,000
Post by noob5,000,000 » Sat Mar 09, 2013 3:54 am
^ Argh, I managed to get that one off with a modified pair of needle nose pliers, but the second one is being a whoreslut. I might have to go buy the correct tool (gasp!).
Also, pressing bushings out of control arms is a bitch. The pressing is only .01% of the effort, the rest is trying to position the piece in a way that will present the bushing to the ram without anything else getting in the way. In many cases this is nearly impossible. I'm going to need to pick up various pieces of round and square stock to come up with ways to get this done.
Post by theholycow » Sat Mar 09, 2013 8:33 am
The nice thing about the correct tool is that it's better for the job than grinding needlenose pliers into an improvised tool. What sucks is that, once you buy the tool, it's never where you can find it. You buy it, use it once, then put it away. The next time you need to use it, where the hell is it? Then you're back to grinding needlenose pliers and prying with a screwdriver.
Post by Rope-Pusher » Sat Mar 09, 2013 9:01 am
noob5,000,000 wrote: The pressing is only .01% of the effort, the rest is trying to position the piece in a way that will present the bushing to the ram without anything else getting in the way.
Fickset
