El Cheapo one-man brake bleeder kit
Test drive a car? Have a favorite oil filter? Love your LCD TV? Post the product in the title and review away!
Post by theholycow » Sat Sep 29, 2012 7:40 am
http://napaonline.com/Catalog/CatalogIt ... 0387035357
http://www.autozone.com/autozone/access ... =46839_0_0_
http://www.pepboys.com/product/details/ ... ake_tools/
http://www.harborfreight.com/one-man-br ... 37201.html
I don't think I got mine at a parts store or Harbor Freight. I'm pretty sure I got it at a discount store many years ago. Photos and reviews indicate that it's the same damn thing everywhere you buy it.
Anyway, I got it for a scant couple of bucks but, owing to my distaste for bleeding hydraulic systems and extreme skepticism about this cheesy looking doodad, it never came out of the package. Last year I failed at bleeding my pickup's brakes with a MityVac, then ended up doing it with a helper to push the brake pedal...that's annoying.
More recently I needed to bleed (and flush) my wife's SUV's brakes. I decided that, despite my skepticism, this thingamabobber was worth a try. The tube fit securely onto the bleeder nipple. The magnet felt a little weak but it never failed to hold the unit to the frame. Now on to the main event: To my surprise, it worked! It worked perfectly, even on the first pump when I wasn't sure the tube would even get filled up.
The small bottle, weak magnet, and potentially short tube are mild annoyances at worst and can all be worked around with minor hacking if you plan to use it often. (I'd recommend a hard drive magnet.) However, if you're a professional or doing this more often then you probably wouldn't waste your time with a $2 to $8 tool, instead using a nice vacuum pump brake bleeding system, or a pressure bleeder at the master cylinder, or even just a souped up version of this same tool. For the DIYer this thing is perfect, those mild annoyances barely register on the same scale as bleeding the brakes without it and the price is right.
Performance: Does the job perfectly.
Handling: Magnet's slightly weak.
Practicality: Bottle's a little small and tube (while plenty long enough for the job I did) may be short for some jobs.
Cost to own: Can't be beat.
Feasibility of sexual encounters: Don't even want to think about it.
Fun factor: Getting the job done so easily without a helper is satisfying. Fun, maybe not.
Result: 4/5, but despite my reservations, highly recommended.
Re: El Cheapo one-man brake bleeder kit
Post by Shadow » Sat Sep 29, 2012 10:26 am
I basically made the same thing using a piece of clear tubing and a 16oz soda bottle.
Just last week I replaced both front calipers on my 4Runner (for the second time!) because the inboard pistons were frozen. This is obviously a design flaw with the calipers....it happens over and over again to just about everyone who owns a 4th generation 4Runner. Anyway, I obviously had to bleed the brakes when I finished installing the new calipers. The rears are incredibly simple. With the key on, you just depress the brake pedal and the pump will continue to push brake fluid through the system until the pedal is released (or the bleeder is closed), effectively removing all air from the line. The fronts have to be bled in a more conventional manner by pumping the pedal.
And of course the job isn't always as easy as that. Somehow, I must have managed to get a bit of air into the ABS module....and the only way to get the air out is to re-bleed with the aid of a scan tool that is capable of opening the ABS valves/solenoids. Since my scan tool doesn't have that capability, I have to either borrow one that does, or pay a shop to do it for me :x
