Because, in applications where it doesn't need to be built for heavy work, it can be lighter; and because the vehicle can be lower. Those motivations do not apply to trucks.Shadow wrote:Here’s why: Think about the reason cars went from BOF to unibody in the first place.
Pickups do not need to be low (quite the opposite in fact - if you were to sell a unibody pickup you'd have to set it at the same height as BOF pickups or nobody would buy it), and while some could benefit from weight loss (half tons used as commuter/family cars), plenty need more weight (anything used for plowing or towing).These advantages would apply equally to a small car or a large pick-up.
In your previous post you conceded that unibodies “can” be built just as strong as BOF but are currently not. It's not that unibody cannot be strong enough to cope.The reason unibody never made it to large pick-ups is because they aren’t strong enough to cope with the stresses that those vehicles are built to endure.
Most of us are looking at this discussion theoretically, talking about what “can” be done but why it is or is not actually done.
I'm sure I've forgotten a couple. What advantages does it have that would apply to pickups and outweigh the advantages of BOF (which, BTW, do not apply to cars)?If the unibody chassis was built just as strong, it would surely be in use by now on large pick-ups and work trucks, simply because of the other advantages inherent of the design.
I think a whole lot more engineering would need to be done to start using unibody on pickups than needs to be done to improve BOF. BOF is mature technology; once in a while someone comes up with a significant change, and of course some engineering is done all the time, but that's on a whole different level from changing to unibody would be. You'd have to re-engineer the entire vehicle, and do additional major long-term testing on the whole thing that doesn't need to be done for BOF pickups.You talk about engineering and testing….do you really think nothing has been done in terms of engineering/testing for a pick-up frame?
Wow, talk about some circular logic.Marketing—nobody will buy a unibody pick-up. That’s probably an accurate statement. But think about the reason why nobody would buy one. If anyone thought a unibody pick-up would hold up, I’m sure they’d be more than happy to buy one. The fact that manufacturers don’t make unibody pick-ups just reinforces public perception that a unibody pick-up wouldn’t last very long.
Manufacturers don't do it because there is nothing motivating them to do so, not because it cannot be done. One of the motivation failures is that nobody will buy it. That doesn't make the general public a better engineer than than the manufacturer's engineering department; it just takes the money out of the idea.
See? We don't disagree at all.Can manufacturers actually build a unibody chassis that would be suited for a fullsize pick-up? Absolutely.
Agreed.So why don’t they do it then? Simple answer—cost. Imagine what it would cost to build that kind of heavy duty unibody chassis. My guess is that it simply wouldn’t be cost effective.
I thought that was obvious enough that we didn't need to discuss it.You still have to consider SUVs though….up until recently, there were plenty of SUVs built BOF. Do you know why? I’ll give you a hint: Many SUVs were derived from pick-up trucks, and pick-up trucks were built BOF.
I disagree. There will always be a market that specifically wants BOF SUVs. More importantly, though, is that the engineering and design are already done for the pickup - there will always be a platform for a quick, cost-effective pickup-sized SUV design with pickup-like capabilities.I have no doubt that the day will come when no new SUV will have BOF construction.
