Is it bad to redline?
1320 feet of adrenaline
Obsidianice
Post by Obsidianice » Sat Dec 23, 2006 1:31 am
Redlining the car in and of itself won't kill your engine...Most cars especially conservative redlines. My car has a 6500 rev limit, but will happily rev to 7200 all day long. The average car can and will rev mechanically be able to rev at least a couple hundred and usually several hundred hundred rpm past red with no problem. If only for the fact that sheer momentum will go over. Becaused the redline says 6500 doesn't always there? WHen shifting my car at 6500 RPM I'll often see it read 6600 RPM on the SAFC. THere's definitely a safefty area built in. But obviously it will cause more wear and tear which can do your engine in sooner that normal driving will. At that point it really depends on the build quality of the motor and if it's properly maintained. So in other words...feel free to wind it out, just take care of it, but don't be shocked if something does break :lol: but don't expect it to.
1991 Nissan Maxima
1996 Infiniti I30t..turbocharged
mulvihill
Post by mulvihill » Sun Dec 24, 2006 4:27 pm
if the engine explodes or you bust something inside will the car just coast to a stop or ... what will happen?
0-60 in.......still counting....
Obsidianice
Post by Obsidianice » Sun Dec 24, 2006 4:42 pm
mulvihill wrote:if the engine explodes or you bust something inside will the car just coast to a stop or ... what will happen?
If the engine busts..to be honest..very little happens. Heck you can break a rod and still drive. So you will most likely just coast to a stop..It's when other parts break within the drive line that the car will do crazy things, like a CV going while moving at speed.
1991 Nissan Maxima
jory543
Post by jory543 » Sat Jan 06, 2007 2:29 am
My engine loses all it's steam by 5500 RPM's so I hardly ever bring it above 5200. The redline on the tach is at 6k and that's where the rev limiter is also. The engine is all about low end torque anyway. It would have more high end power if I was running a manual ECU, right now I have an automatic computer. The manual computer would also let it rev higher before cutting off fuel.
JRicoCTG
Post by JRicoCTG » Sat Jan 06, 2007 2:36 am
my car redlines at almost 7000......i tihnk. i dont go up that high too much, so im not certain. but it starts loosing power....well the little power it has at about 5000. so no need for me to go any higher.
someone should take one for the team and downshift over the rev limiter with an old POS car. make a video. it would be interesting.
There's No Rehab for Stupidity.
1994 Mazda MX-3
screenname
Post by screenname » Sat Jan 06, 2007 2:44 am
JRicoCTG wrote:someone should take one for the team and downshift over the rev limiter with an old POS car. make a video. it would be interesting.
How about one with an Acura RSX Type-S? It's a repost, but it's still pretty entertaining to watch:
http://www.youtube.com/watch?v=Tx4wYE-0ubA
eaglecatcher
Cars: '90 300ZXTT 5MT
Post by eaglecatcher » Sat Jan 06, 2007 2:49 am
hahahahaha. That sucks. I'm careful with my shifting. If I'm not sure that its in the right gate, I won't let the clutch out. It could still happen, but that would suck.
Z1 Intake
Z1 2.5" Test pipes
HKS 65mm Hi-Power Exhaust
AMS Short Shifter
SZ Subframe Spacers
HKS Vein Pressure Converter
DDM Tuning 6000k HIDs
Obsidianice
Post by Obsidianice » Sun Jan 07, 2007 4:34 pm
JRicoCTG wrote:my car redlines at almost 7000......i tihnk. i dont go up that high too much, so im not certain. but it starts loosing power....well the little power it has at about 5000. so no need for me to go any higher.
I've done it...it's not fun, the rdline on my car is 6500. It only went to 7500 on the missed shift though. On my car that's still within liveable range thankfully. Much more than that it would have been very bad though :shock:
1991 Nissan Maxima
mesaboogie18
Cars: 2004 VW GTI 1.8T 5speed
Post by mesaboogie18 » Sun Jan 07, 2007 5:57 pm
On the highway the other day I was shifting from 4th to 5th and accidentally put it in 3rd. It didn't over rev, it just was like regular downshifting. I thought something was funny when I shifted "up" and started accelerating faster and my engine was louder.
2004 VW GTI 1.8T
wychwood
Post by wychwood » Sun Jan 07, 2007 10:16 pm
The highest RPMs I've reached on my car is about 3500 in 5th gear. I can't even imagine reachin' redline. If I did, I'm sure my little Hyundai Accent would totally crack up into little itsy pieces. I personally hate the sound the engine makes when I rev too high in any gear. I rarely go above 2500 in 1st & 2nd. Occasionally in 3 or 4th I'll take it 3000 for smoother shifts. In top gear (5th) I cruise on the highway at 3000.
Oldladykiller
Post by Oldladykiller » Wed Apr 18, 2007 2:53 pm
i guess it depends on the engine. but i wouldnt worry about taking it to the redline at all. just dont mis shift at redline or go past it that much.
hai1206vn
Post by hai1206vn » Wed Apr 18, 2007 5:33 pm
Most of the broken parts will stay within the block, so I guess you won't see a lot of damage to other parts. When the engine explodes, it'll be like putting your car in neutral and turning the key off. No torque moving the car, no brake booster, no power steering. The only difference is visual.
"Being second is to be the first of the ones who lose." - Ayrton Senna
Badmojo
Post by Badmojo » Wed Apr 18, 2007 7:25 pm
General consensus on the RX-8 forum is that if you aren't redlining these cars once a day, you're probably accumulating carbon deposits. In fact, the cars with automatic transmissions seem to suffer more engine problems because their owners tend not to drive them as hard as the manuals. Whether you'd want to apply this same logic to a piston engine, I don't know. When I had my 4-cylinder Mazda3 the engine always sounded like it wanted to esplode any time I got near redline. I guess there's more stuff to go wrong... valves, cams, cranks, etc.
2004 Mazda RX-8 GT
eaglecatcher
Post by eaglecatcher » Wed Apr 18, 2007 7:33 pm
I shift about 4200 for max performance,because I don't get any hp once I'm in the 4k range, so its best for me to shift then, plus I land in a decent spot in the next gear, so it all works out.
Z1 Intake
Z1 2.5" Test pipes
AMS Short Shifter
SZ Subframe Spacers
hai1206vn
Post by hai1206vn » Wed Apr 18, 2007 8:34 pm
eaglecatcher wrote:I shift about 4200 for max performance,because I don't get any hp once I'm in the 4k range, so its best for me to shift then, plus I land in a decent spot in the next gear, so it all works out.
Don't know about your engine and tranny, 4k might be a bit early. Sure the torque there is falling, but power may still be before its peak.
