EricTheCarGuy teaches you to drive stick
All things photo, moving or not.
Post by Shadow » Sat Mar 16, 2013 11:43 am
Re: EricTheCarGuy teaches you to drive stick
Post by bk7794 » Sat Mar 16, 2013 8:40 pm
His clutch change on that car was pretty cool to see. Definitely a quality youtube repair man.
2000 Honda Civic EX 5 Speed
Volvo S60R 6 Speed - Sold
Post by Rope-Pusher » Sat Mar 16, 2013 9:22 pm
The Clutch should be thees far up off the downstop when eet begins to grab - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:24 pm
Wait at least 24 hours for the paint on the shift knob to dry - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:27 pm
...and then this idiot comes driving toward me down the one-way street - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:30 pm
So I was driving this semi, hauling a load of watermelon to Alaska, when the road turned to a sheet of ice - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:33 pm
I don't care what you are driving, 10 speeds is too many gears - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:37 pm
When the tips of the gear teeth try to mesh together, it is called "Tooth Butt" - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:41 pm
When the engine rpm starts to drop, hesitate releasing the clutch for a second or it will tend to grab abruptly - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:44 pm
I thought I was changing the radio station, but I was too drunk to know that it was an old Chrysler Push-Button transmission and instead I shifted it into Reverse at 70 mph - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:47 pm
......a see-saw motion, letting up on the clutch pedal as you press down on the accelerator pedal - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 9:54 pm
Here is the church and here is the steeple,..... - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 10:01 pm
The shift knob was small and uncomfortable to grasp - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 10:02 pm
Possibility of sex: 0 - Hamid Carguy
Post by Rope-Pusher » Sat Mar 16, 2013 10:06 pm
1st gear, it's all right,
2nd gear, I lean right,
3rd gear, hold on tight,.... - Hamid Carguy
