Downshift Fail!
MidnightInGotham
Cars: 2016 GTI
Downshift Fail!
Post by MidnightInGotham » Mon Oct 17, 2016 8:46 am
This morning on my way to work, I was going to attempt a quick heel toe just to practice (first attempt). It's early and I'm trying to concentrate...slowing down, moderate breaking...moved the stick from 6>5 and completely forgot the clutch!!!!!!! :shock:
Now there were no grinding sounds or anything alarming from a feel or sound standpoint and the effort was not extreme. Obviously don't ever do this, but did I do any damage here? I'm still fairly new to this but this one made me want to curl into the fetal position and cry myself to sleep.
Please let me know what I'm in for!
Re: Downshift Fail!
Post by IMBoring25 » Mon Oct 17, 2016 8:49 am
Nope...If you've done any damage at all there should be either noises or excessive shift effort.
MidnightInGotham
Cars: 2016 GTI
Re: Downshift Fail!
Post by MidnightInGotham » Mon Oct 17, 2016 8:56 am
IMBoring25 wrote:Nope...If you've done any damage at all there should be either noises or excessive shift effort.
Gosh, that's a great thing to hear. I mean I had my music on and such but I would imagine I'd hear something over that.
Re: Downshift Fail!
Post by tankinbeans » Mon Oct 17, 2016 10:54 am
You'll find "experts" all over the web who will say they only use the clutch to start moving and then no-clutch it from there forward. If the car is in the same number of pieces as before and no sounds are emanating from inappropriate places you're likely fine.
MidnightInGotham
Cars: 2016 GTI
Re: Downshift Fail!
Post by MidnightInGotham » Mon Oct 17, 2016 11:03 am
Also what type of wear would this cause? I assume synchro? Gears?
Re: Downshift Fail!
Post by tankinbeans » Mon Oct 17, 2016 12:15 pm
MidnightInGotham wrote:Also what type of wear would this cause? I assume synchro? Gears?
From what I've learned this would likely lead to increased wear on your synchros as the gears themselves are in constant mesh.
Re: Downshift Fail!
Post by IMBoring25 » Mon Oct 17, 2016 12:55 pm
The gear portions of the gears are in constant mesh, but there are dog teeth on the faces of the gear that interface with the collar to engage specific gears. That interface is where the potential damage can occur when you hear grinding.
MidnightInGotham
Cars: 2016 GTI
Re: Downshift Fail!
Post by MidnightInGotham » Mon Oct 17, 2016 1:02 pm
IMBoring25 wrote:The gear portions of the gears are in constant mesh, but there are dog teeth on the faces of the gear that interface with the collar to engage specific gears. That interface is where the potential damage can occur when you hear grinding.
Is this typically pretty loud when it happens? Like I said I had my music on but didn't hear anything. Also the car went into 5th just fine after that.
Would I notice something if there was damage. Car only has 6k miles on it so I'm hoping nothing is wrong.
Re: Downshift Fail!
Post by theholycow » Mon Oct 17, 2016 1:40 pm
It's not hard to do what you did. Everybody slips up and does it a few times. The guys who designed and built your car know that, and it's made to survive without damage.
When you do it usually it will grind, but sometimes it'll just snap right into place. You may not have heard it because loud music but you probably would have felt it very obviously in the shifter; it sounds like for you, this time, it just snapped in.
If there was damage or notable wear, you wouldn't be asking us...you'd be telling us. It would be obvious and you'd probably have brought it to a professional already, but if not then you'd be telling us about the clear and obvious symptom that you have now.
Everything is fine and there's nothing to worry about.
Teamwork
Cars: 2015 VW GTI
Re: Downshift Fail!
Post by Teamwork » Mon Oct 17, 2016 2:45 pm
It's really kind of crazy to think about but I play out this scenario in my head all the time (w/o actually doing it) but I usually come to the conclusion that I'm impressed that I haven't accidentally forgot one of the thousands of times of changing a gear.
Re: Downshift Fail!
Post by tankinbeans » Mon Oct 17, 2016 2:52 pm
I had this happen last week. I was chaging lane, and was 3/4 into my desired lane, when all of a sudden some moron comes wandering over into my front fender. I swerved back right and tried to hit 3rd, but wound up in an unrevmatched first gear; the clutch was an afterthought.
I wound up chirping the tires after a 5000 rpm 1st gear downshift.
Re: Downshift Fail!
Post by bk7794 » Mon Oct 17, 2016 5:05 pm
Last week I was driving my car. Downshifted into third and for some reason started letting the clutch out before I put it into third. Needless to say I felt and heard the gears grinding. Third still works as before.
Doing it once in a while won't do any excess damage. Just don't make a habit of it.
2000 Honda Civic EX 5 Speed
Volvo S60R 6 Speed - Sold
MidnightInGotham
Cars: 2016 GTI
Re: Downshift Fail!
Post by MidnightInGotham » Mon Oct 17, 2016 7:42 pm
bk7794 wrote:Last week I was driving my car. Downshifted into third and for some reason started letting the clutch out before I put it into third. Needless to say I felt and heard the gears grinding. Third still works as before.
For my own sanity, did you have music on in your car and could you clearly hear the grind over that?
MidnightInGotham
Cars: 2016 GTI
Re: Downshift Fail!
Post by MidnightInGotham » Mon Oct 17, 2016 7:44 pm
tankinbeans wrote:I had this happen last week. I was chaging lane, and was 3/4 into my desired lane, when all of a sudden some moron comes wandering over into my front fender. I swerved back right and tried to hit 3rd, but wound up in an unrevmatched first gear; the clutch was an afterthought.
So you went from 4>1 accidentally with no clutch? Any grind? That one surprises me because I think my car locks me out of first above like 6 mph on a downshift.
MidnightInGotham
Cars: 2016 GTI
Re: Downshift Fail!
Post by MidnightInGotham » Mon Oct 17, 2016 7:46 pm
theholycow wrote:It's not hard to do what you did. Everybody slips up and does it a few times. The guys who designed and built your car know that, and it's made to survive without damage.
Thanks Cow, you always put my mind at ease.
