InlinePaul wrote:I don't do the rev matching, but downshifting into first I routinely blip the throttle to ease the syncronizer engagement, but not worry about matching for engaging the clutch.
I assume you're double-clutching, otherwise you're not helping the synchro at all.
As for downshifting to pass, anticipate it and get into the lower gear before you pull out to pass, even if you have to run higher RPMs for a little bit. That way you can be focused on the lane change and just floor it when you move over. I do it that way all the time.
If we're talking about planning ahead and using actual strategy for a pass like that, I like to back way off (even further than my normal long following distance), then charge at the rear of the car in front as my opportunity approaches, timed so I just slingshot around during my window. This eliminates any worry about not having enough power (not an issue in some vehicles, but relevant in your I4 Ranger and my car), eliminates any issue of a personally offended driver trying to block your pass (and avoids offending them in the first place), is easily aborted right up to the last second if you have any doubts (unless your brakes suck, I guess), and requires a smaller window for a successful pass no matter how much power you have.
Learn to launch/FAQs/lugging/misused terms:
meta-sig
