V6 Pony vs.'04 Honda Accord
Did you win or lose? Please drive safely!
Re: V6 Pony vs.'04 Honda Accord
Post by watkins » Sun Jan 10, 2010 5:44 pm
Transverse is indeed the correct term.
07_Mustang V6
Cars: 07 Mustang V6
Post by 07_Mustang V6 » Sun Jan 10, 2010 7:24 pm
Alright thanks. Why not just say front wheel :) haha
2007 Mustang V6 5spd.
Post by watkins » Sun Jan 10, 2010 7:29 pm
Because it doesnt have to be transverse to be FWD. Nor does it have to be longitudinal to be RWD
Post by IMBoring25 » Sun Jan 10, 2010 7:47 pm
Because it refers to the layout of the engine. FWD tends to use a transversely-mounted engine and RWD tends to use a longitudinally-mounted engine, but neither is universal.
Some noteworthy FWD vehicles with longitudinally-mounted engines:
Most Audis
Some old Renaults
FWD Cadillacs prior to 1986
Some noteworthy RWD vehicles with transversely-mounted engines (Yeah, so they're MR, not FR...It would be tough to justify that design choice for an FR):
Pontiac Fiero
Toyota MR2
Lotus Elise
Acura NSX
Ariel Atom
07_Mustang V6
Cars: 07 Mustang V6
Post by 07_Mustang V6 » Sun Jan 10, 2010 8:05 pm
Alright that cleared up a lot. I'm still new to the world of cars so I still gotta catch up on a lot of terms to get closer to the same level as you guys
Post by watkins » Sun Jan 10, 2010 8:32 pm
Just dont forget to clear your blinker fluid passages and top it off every 7k miles. A lot of new drivers fall behind and it causes quite a few problems down the road.
Post by theholycow » Sun Jan 10, 2010 8:40 pm
That's bull. You just don't need to clear the blinker fluid passages that often, unless you're using some awful blinker fluid or there's something wrong with your car.
I have always cleared my blinker fluid passages every 40,000 miles and never had a problem. I do use top-quality synthetic blinker fluid, though.
94Corolla5Speed
Post by 94Corolla5Speed » Sun Jan 10, 2010 8:46 pm
But this is a Mustang. Ford blinker fluid has crystallized azure ovals for increased brightness.
Post by theholycow » Sun Jan 10, 2010 8:57 pm
Oy! WTF is Ford thinking with those stupid crystals? Concentrated liquid win is available that would blue and brighten the fluid just right without requiring more frequent maintenance. I'd flush the system and replace the fluid with standard blinker fluid, adding win modifier to give it OEM qualities.
Post by watkins » Sun Jan 10, 2010 9:00 pm
Call me old fashion, but I stick with frequent changes as per yesteryear's advice. I change my oil every 3k miles on the dot, and blinker fluid every 7k. Theres definitely no harm in keeping things fresh.
Post by theholycow » Sun Jan 10, 2010 9:04 pm
:evil: In your earlier post you only said to top it off and clean the passages every 7k miles, not to change it.
What, am I the only person here who is a skeptic? Am I the only one who realizes that the blinker fluid industry has been pushing those silly intervals for too long? Modern designs and manufacturing techniques result in a vehicle that just doesn't need blinker fluid changed so often. More is bad for the environment, though good for the economy.
Post by watkins » Sun Jan 10, 2010 9:17 pm
Sorry. Misstyped. I do indeed only clean the passages every 7 thousand miles. Ive never owned a car long enough to require a flush and refill.
LHOswald
Cars: '99 Civic Hatch w/B16a
Post by LHOswald » Sun Jan 10, 2010 9:33 pm
you guys are all retarded haha. :twisted:
transverse (thank you for correcting me) mounted RWD vehicles are usually MR or RR drivetrains, meaning that the engine is in between the axles (MR) or behind the rear axle (RR). longitudinally mounted FWD cars such as any audi with quattro, are FWD until the front wheels start to slip, and then through a VCD (varible center differential) controller it connects the rear wheels to the front so that you get better traction.
Post by watkins » Sun Jan 10, 2010 10:05 pm
LHOswald wrote:you guys are all retarded haha. :twisted:
You wont be saying that when your lines clog up.
LHOswald
Post by LHOswald » Sun Jan 10, 2010 10:09 pm
im sure they'll do just fine. the real problem i have to worry about is im pretty sure my muffler bearing is starting to go :evil: not an easy fix on a b2200 of my generation. there are like 5 differentials in the way for you to even get to it, and once you do its encased inside the catalytic converter. not looking forward to that repair bill
