full throttle and short shifting
ok, heres the story. my previous car was automatic and i rarely put the foot to the floor when overtaking cars, etc because i know it will go all the way to redline which will obviously lead to wear at tear.
but now in the manual, sometimes i like to use full throttle then shift early (usually at 4000-4500rpm) since i have the option to do this in a manual car and not auto.
is this a common thing to do on manual cars, use full throttle but short shift? does it cause more wear and tear to the engine compared to accelerating slowly to 4000rpm?
any feedback appreciated, thanks.
I believe scionkid is an advocate of full-throttle shifts, but I may be mistaken because he refers to them as wide-open throttle shifting.
In any case, short shifting at high revs sounds like a contradiction to me Unless of course you don't consider 4000 or 4500 high. Are you talking about really quick sprints in each gear until you reach the highest gear for the current conditions?
my car has a redline of 7500rpm so 4000rpm isnt all that much but i usually dont take my car over 4000rpm anyway during normal driving conditions.Hatchman wrote:I believe scionkid is an advocate of full-throttle shifts, but I may be mistaken because he refers to them as wide-open throttle shifting.
nah im not talking about quick sprints to the highest gear. usually when i do this, it will only be for one gear (the gear im currently in) or two gears max. but usually i do it on the 3-4 shift.
The definition of brow beatingjomotopia wrote:well you must remedy that on your next drive! i task you to go full throttle, to redline, through as many gears as you can until you're just going too fast. do it!Hatchman wrote:Duh yeah I guess LOL. I don't think my gas pedal has ever really hit the floor though
- Cars: 05 Mazda 3 GT
+1 LOL The car benifits from being FT once in a while.. do it Hatchman! LOL Show that "Sport Sedan" next to you who's bossjomotopia wrote:well you must remedy that on your next drive! i task you to go full throttle, to redline, through as many gears as you can until you're just going too fast. do it!Hatchman wrote:Duh yeah I guess LOL. I don't think my gas pedal has ever really hit the floor though
Maybe and yes. WOT short-shifting improves engine efficiency, which may or may not have an effect on fuel economy. And WOT short-shifting, believe it or not, contributes to less engine wear because it allows maximum combustion efficiency, leading to less deposits.paul34 wrote:I've always been curious about this as well
Is there a differnece between going WOT to your shift point vs. accelerating slowly up your shift points in regard to fuel efficiency and engine wear?
- Cars: 04 xB
IMO, short shifting should be done at about the first 1st of the rev range. In the case of a 7500 rpm engine, short shifting would be to shift at 2500 rpm. And when you do short shift, the car accelerates slowly even if you use WOT.
Generally, the less power you use to accelerate, the more fuel you'll save. There are 2 ways to limit the engine's power output. The universal way is to tread lightly on the throttle and this limits the amount of air an engine can aspirate. The 2nd way is to use a high gear and WOT. Since the high gear limits engine speed, this limits the number of air intake.
The theory is that WOT is somewhat more efficient because the engine doesn't have to burn extra fuel to suck in air through a small throttle opening. However, it burns more fuel per engine revolution, which means more heat is transfered to the cooling system, and you need to keep an eye out for the temperature gauge.
- Standardshifter
- Site Admin
- Cars: 2005 Legacy GT, Buell
