Slaves
Slaves
So the big thing for the past 20 or 30 years is the concentric slave cylinder inside the transmission (around the input shaft). These can be a real pain as there is no adjustment and any time you have to monkey with it, you have to yank the tranny.
So I inspected several front drive manual cars and they all have external slave cylinders and a clutch fork. Why did they not go with the concentric slave on the front drivers? And thankfully they didn't. If one is stuck with front drive, they can at least say there is one logical feature besides the manual transmission, and that is the clutch fork.
I think much grief could be spared if slaves were all external. Yes I had major grief with the 2001 Ranger and have zero desire for another Ranger manual after that.
My 1984 F150 had the external slave and I changed out the clutch without having to bleed the system. Truck ran for years after that just fine and never needed any hydraulics work.
Re: Slaves
You know what sucks? JK Wrangler clutch fork squeak.
Concentric slaves save space and apply a more even pressure. They are, from a technical standpoint, the superior design. Considering a slave cylinder isn't really a regular fail point, service simplicity definitely takes a back seat. The only real drawback is that they often seem to have rather terrible bleed valve designs on newer cars. At least on the Italian garbage I deal with. Fix that, no problem.
Re: Slaves
....and space IS the final frontier, no matter what Nissan says!
and concentric slaves are less likely to get battered / knocked out of place when you drive over a fallen tree branch.
The even pressure thang is good too, as well as they eliminate tolerances (fewer system components), cost (fewer components again) and and the geometric inefficiencies of a fork / release lever moving in an arc whilst trying to press the release bearing squarely against the fingers of the diaphragm spring in the clutch cover.
Yanno, even if you made them as two halves that bolt together around the input shaft quill, there still isn't room in the bellhousing to unbolt them and remove them until you separate the trans from the engine. There often isn't even enough space to swing a clutch fork!
Re: Slaves
That were another question I had, can one convert a concentric to an external. Not really, unless want to get a different bell housing and shorten the drive shaft i guess, but not work for front drive,Rope-Pusher wrote: ↑Wed Aug 25, 2021 2:01 pm
But then what is driving the presence of clutch forks in front drive vehicles? there must be some engineering drawback to the internal concentric in that configgeration.
Fact is I am against slavery, so the cable actuated clutch in the 1992 Mustang is perfect.
So who named it a slave anyway. We didn't call wheel cylinders on the old drum brakes slaves.
Re: Slaves
Here is who named it "The Slave Cylinder":ClutchFork wrote: ↑Wed Aug 25, 2021 6:58 pmThat were another question I had, can one convert a concentric to an external. Not really, unless want to get a different bell housing and shorten the drive shaft i guess, but not work for front drive,Rope-Pusher wrote: ↑Wed Aug 25, 2021 2:01 pm
I don't know that there is a trend for FWD to use cable or external slave in their clutch release systems...except to say that Concentric slave cylinders are relatively new......and many inexpensive Amish vehicle have designs based in the 1980s, when cables were the norm and if they had slave cylinders they were external.
Re: Slaves
I don't know who that robot guy is but he looks kind of nasty. If he is from TV or the movies, well I have not tuned in to any of that since 1989 (does that make me Amish?).
But is looking for the reason of external slaves on FWD I found a conversion article from concentric to external. So there is still hope. In fact, they call it a slave cylinder upgrade:
https://www.motortrend.com/how-to/1602- ... r-upgrade/
Further, I discovered the pesky designers were part of the problem. This next article says, "...and closer fit to the transmission which increases flexibility in passenger compartment design."
https://10secondracing.com/pages/concen ... e-cylinder
Re: Slaves
That's probably part of it, and it's not as much flexibility of design as it is flexibility of installation. The more compact and self-contained package is more likely to be able to be reused if you then wind up hanging it with a different engine or in a different vehicle. There likely isn't as much other stuff competing for that particular patch of space in a transverse installation.
Concentric is better on pretty well every metric except maintenance. Of course, both vehicles I've had that needed slaves, they were the first important failure in the clutch system, so it wasn't even a matter of, "Something else will fail first, be sure to change it while you're in there." On the other hand, they were also both WAY, WAY out of warranty, when the manufacturer really probably doesn't care too much either way.
Re: Slaves
You arent familiar with "THE MASTER CYLINDER!"?ClutchFork wrote: ↑Wed Aug 25, 2021 11:57 pm I don't know who that robot guy is but he looks kind of nasty. If he is from TV or the movies, well I have not tuned in to any of that since 1989 (does that make me Amish?).
https://felixthecat.fandom.com/wiki/Master_Cylinder
Re: Slaves
Wow. I remember Felix the cat but not the Master Cylinder. I may have been in single digit age but there is a lot of way back stuff I don't remember. In fact, if I remember anything of Felix, it was the funny voice, and wasn't there an episode where a boy plugged a leaking dike with his finger to keep the town from flooding? Or maybe I got my cartoons mixed up. But as a small child I was glued to the television for the entire morning of Saturday cartoons and remember great disappointment when the cartoons were pre-empted by the funeral of an assassinated president.Rope-Pusher wrote: ↑Thu Aug 26, 2021 8:11 pmYou arent familiar with "THE MASTER CYLINDER!"?ClutchFork wrote: ↑Wed Aug 25, 2021 11:57 pm I don't know who that robot guy is but he looks kind of nasty. If he is from TV or the movies, well I have not tuned in to any of that since 1989 (does that make me Amish?).
Re: Slaves
I'm imagining that some cartoonist was having brake system issues with his car and that's why he named Felix's arch-enemy "The Master Cylinder"ClutchFork wrote: ↑Thu Aug 26, 2021 10:54 pmWow. I remember Felix the cat but not the Master Cylinder. I may have been in single digit age but there is a lot of way back stuff I don't remember. In fact, if I remember anything of Felix, it was the funny voice, and wasn't there an episode where a boy plugged a leaking dike with his finger to keep the town from flooding? Or maybe I got my cartoons mixed up. But as a small child I was glued to the television for the entire morning of Saturday cartoons and remember great disappointment when the cartoons were pre-empted by the funeral of an assassinated president.Rope-Pusher wrote: ↑Thu Aug 26, 2021 8:11 pmYou arent familiar with "THE MASTER CYLINDER!"?ClutchFork wrote: ↑Wed Aug 25, 2021 11:57 pm I don't know who that robot guy is but he looks kind of nasty. If he is from TV or the movies, well I have not tuned in to any of that since 1989 (does that make me Amish?).
Could just as well been named "The Self Adjuster" if that had been the offending component.
Re: Slaves
And had it been in the mid 1980s and the cartoonist had an F150, it could have been named "The Ignition Module."Rope-Pusher wrote: ↑Fri Aug 27, 2021 8:41 am Could just as well been named "The Self Adjuster" if that had been the offending component.
Re: Slaves
Did anyone ever come up with an answer to this:
Re: Slaves
I kinda said something about it on the post with the Master Cylinder.....Not as much has ben redesigned on the FWD Amish transmissions...they are mostly just building what they've been building, in order to keep them inexpensive.ClutchFork wrote: ↑Sun Sep 12, 2021 1:20 pm Did anyone ever come up with an answer to this:
Re: Slaves
Ah yes, now I see it. Well, another consideration, but one the manufacture typically does not seem concerned with, is the difficulty of changing the slave in a transverse engine/tranny. I don't know how easy it is to drop the tranny in a front driver, but I would think it is worse than a rear driver since the differential gear assembly must be packaged with the tranny. so probably have to remove one or both axle shafts before you can drop the tranny?Rope-Pusher wrote: ↑Sun Sep 12, 2021 3:59 pmI kinda said something about it on the post with the Master Cylinder.....Not as much has ben redesigned on the FWD Amish transmissions...they are mostly just building what they've been building, in order to keep them inexpensive.ClutchFork wrote: ↑Sun Sep 12, 2021 1:20 pm Did anyone ever come up with an answer to this:
The external slave is visible from above and presumably can be reached from above in a number of front drivers.
Re: Slaves
The ease of transmission removal is entirely dependent upon the vehicle and transmission in question. Neither are manuals, but an RT minivan with a 62TE is a hell of a lot faster to pull than a WK2 with an eight speed; even in the rare RWD configuration.
