Pop off cap, fill, paint, replace.FDSpirit wrote:The S2K one is nice though
If I could get one like that, I'd be very happy. But since my car only has 5 speeds, that would look a little, well, cheesy
Interesting bit on shift knob weight
Re: Interesting bit on shift knob weight
- comingbackdown
- Cars: 2013 Ford Fiesta
Yes. Yes it is.FDSpirit wrote: . The Tick???!!
Win.
- 1974Alfa5spd
You don't need a weighted shifter when the actual shifter is longer than your arm.
i think for the most part, oem shift knob weights are optimized for the general populace's specs - be it average hand size, arm length, and feedback of "notchiness" etc. in other words, the oem shift knob weight is the best matched weight for that particular transmission for the general public.
having said that, as enthusiast drivers, heavy vs. light knobs will always be a personal preference. my current shift knob is lighter than the oem but its a sphere shape, whereas the oem is a teardrop shape. it fits better in my hand and it takes no more effort to shift than it did with the oem knob. having said that, shift "feel" doesn't have than solid "thunk thunk" feeling when changing gears... i'm not sure if i like the lighter knob, but, i do like how the sphere shapes fits in my hand. when i tire of this one, i'll probably look for a oem weight or slightly heavier sphere shaped knob...
08' Acura TSX ASM/Ebony 6MT
One, or two, could write a thesis on matching shift detents to knob mass to get the perfect shift action - and it would still be a matter of a pinion.
My duracon shift knob is like 70grams lol, I've tried a 380gram shift knob and it does make a huge difference, you don't feel any syncro resistance but didn't really like the ball shape and the metal knob was slippery and burning hot in summer.
I should have named this thread "knob job".
My knob is probably 5.5-6oz (156-170g). It appears to have had a previous life as an 8-ball, though now it's just a plain black ball approximately the size, shape, and material of a billiard ball.
I guess I won't bother playing with knobs then.1974Alfa5spd wrote:You don't need a weighted shifter when the actual shifter is longer than your arm.
Where would I go to look and see if anybody sells a shifter knob in the shape of Clifford The Big Red Dog's head? I know, I know, I know, GOOGLE IT! Are there any preferred vendor's of my fellow SSers? I've seen the ones that look like skulls, and find them very interesting indeed.
My factory knob is falling apart. The rubber bit under the top glossy plastic cover that contains the shift pattern is deformed and is coming undone. I'm deliberating to go aftermarket or go to dealer for replacement.
One more thing to obsess over!
My knob is a hardball which is supposed to weigh 5 ounces, so about 140 grams. Maybe that is why some of
my gears are a bit notchy? Of course, a longer shift lever may compensate for a lighter weight knob.
Notice the OEM pattern insert from original shift knob is now mounted in the cigarette lighter hole to the left of the radio.
I want a Curly Howard head for a shift knob. Nyuk nyuk nyuk!tankinbeans wrote:Where would I go to look and see if anybody sells a shifter knob in the shape of Clifford The Big Red Dog's head? I know, I know, I know, GOOGLE IT! Are there any preferred vendor's of my fellow SSers? I've seen the ones that look like skulls, and find them very interesting indeed.
1) Obtain Clifford toytankinbeans wrote:Where would I go to look and see if anybody sells a shifter knob in the shape of Clifford The Big Red Dog's head? I know, I know, I know, GOOGLE IT! Are there any preferred vendor's of my fellow SSers? I've seen the ones that look like skulls, and find them very interesting indeed.
2) Decapitate
3) Mount to shift lever
4) ...
5) Profit!
Longer lever really won't change it all on its own, it's the mechanical advantage that's involved that affects it. A longer lever with the fulcrum further from the load will have the same MA and therefore knob weight will have the same effect. Of course we don't know how yours is setup, but even if we did we'd still be comparing apples to oranges. Every transmission is different and yours may naturally be more notchy than another.InlinePaul wrote:One more thing to obsess over!
watkins wrote:1) Obtain Clifford toytankinbeans wrote:Where would I go to look and see if anybody sells a shifter knob in the shape of Clifford The Big Red Dog's head? I know, I know, I know, GOOGLE IT! Are there any preferred vendor's of my fellow SSers? I've seen the ones that look like skulls, and find them very interesting indeed.
2) Decapitate
4) ...
5) Profit!
These Mazda transmissions in Ford trucks tend to be notchy--so I have heard and experienced. I weighed a baseball and an aftermarket shift knob. They were within about half an ounce in weight. Doesn't seem the factory knob was any heavier. Every floor shifted vehicle I have had has been a Ford truck and eventually the knob pulled off on a hard 1-2 shift, sometimes throwing the knob.theholycow wrote:Longer lever really won't change it all on its own, it's the mechanical advantage that's involved that affects it. A longer lever with the fulcrum further from the load will have the same MA and therefore knob weight will have the same effect. Of course we don't know how yours is setup, but even if we did we'd still be comparing apples to oranges. Every transmission is different and yours may naturally be more notchy than another.
I visualized that and LOL'd.InlinePaul wrote:Every floor shifted vehicle I have had has been a Ford truck and eventually the knob pulled off on a hard 1-2 shift, sometimes throwing the knob.
With a nice long lever, one could conceivably experiment with duct-taping weights on to see how they affect shifting. Hmm...I too have a long lever...who am I kidding I'm too lazy for that. Though, mine is hollow so it would be easy to do it permanently and have it look fine.
