Jastreb's 2009 Mazda Rx-8, "Isabella"
Re: Jastreb's 2009 Mazda Rx-8, "Isabella"
My manly beard combs itself.
AHTOXA wrote:Lengthy commuting kills time that I could use to: masturbate excessively, experiment with matches, drink beer, pickup a hot neighbor chick, have kinky sex.
Forget what I said about long commutes.
Post by Squint »
Don't forget the crap, arrests, lycra shorts, diarrhea, and lube (hehehe, lube...). That last is actually probably positive, but the word lube is funny so I just wanted to mention it. Lube...
Squint wrote:Don't forget the crap, arrests, lycra shorts, diarrhea, and lube (hehehe, lube...). That last is actually probably positive, but the word lube is funny so I just wanted to mention it. Lube...
...I was trying to forget those things because they weren't important compared to the things I quoted. Especially kinky sex. Dirty, weird, kinky sex.
Post by Squint »
theholycow wrote:...I was trying to forget those things because they weren't important compared to the things I quoted. Especially kinky sex. Dirty, weird, kinky sex.
[youtube]www.youtube.com/watch?v=jHPOzQzk9Qo[/youtube]
As I can't see the video at work, I'm hoping it's the right link...
EDIT: post fail, have to fix it later.
That's one of the only musical numbers I've ever enjoyed in movies/TV. Image
theholycow wrote:
(Just sews thairs no misconceptions, Jud is the feller on the rite)
Jastreb
Cars: 2009 Mazda RX-8 R3, Blue
Post by Jastreb »
Well, it appears 1 of my rotors is on the way out. 97k miles
#rotaryproblems
2009 Mazda RX-8 R3
Isnt that a ton of miles for a rotary though?
I don't remember having any issues with the ones Ma Bell provided. We didn't own them - paid monthly lease fees, but they were built like masonry feces domiciles. After the phone company was broken-up, the cheap junk started appearing. I don't even want to talk about the horrid durability of anything that fits in our pockets.
From what I've heard the apex seals usually go out like clockwork at about 60K. Doesn't sound like it owes you anything.
Yeah, having read other auto forums, 60-80k is usually the standard for apex seals.
Jastreb wrote:Well, it appears 1 of my rotors is on the way out. 97k miles
#rotaryproblems
So what are you going to do? Are you going to be looking at a rebuild or replacing the car?
Post by Squint »
IMBoring25 wrote:From what I've heard the apex seals usually go out like clockwork at about 60K. Doesn't sound like it owes you anything.
As someone who only has a basic understanding of rotary engines, does this mean that they typicaly need more routine "overhaul" type maintenance than typical 4-cylinder or 6-cylinder engines? Is the rest of their maintenance lower to counter that higher cost? Otherwise, I can see a clear reason why they haven't caught on more, beyond the "it's different that what we're used to" argument you'll get from the general, non-caring public.
My experience is also limited, but yes, rotary motors do need much more frequent overhaul. Their biggest issue are the apex seals, which will wear out far sooner than, say, piston rings.
The rest of the maintenance isn't lower, either, as it doesn't really get much lower than nothing but oil changes on modern timing-chain driven motors. Even if you have a timing belt/waterpump to be done around 100k miles, it's still cheaper than apex seals.
Plus, a few RX-8 owners run pre-mix (oil and gasoline) when filling up, so that adds into the cost. It's not required, through, as the RX-8 has an oiling system, but forums have claimed better gas mileage with pre-mix.
