jumpy shifts
jeff6666p
jumpy shifts
Postby jeff6666p » Sun Jan 31, 2016 8:19 pm
I just notice I'm having jumpy shifts when shifting at 4k +. If I let the revs drop before letting the clutch out it's fine but if release the clutch after it's in gear it bounces forward then back then goes. if I don't get on the gas as quick it smooths out, it seems like the clutch isn't bitting right away. I tried the slip test and the clutch wasn't slipping . Is it me or the car? I think I have a sticking calipr could that be a cause?
98 3000gt base model
Re: jumpy shifts
Postby potownrob » Mon Feb 01, 2016 4:20 am
jeff6666p wrote:I just notice I'm having jumpy shifts when shifting at 4k +. If I let the revs drop before letting the clutch out it's fine but if release the clutch after it's in gear it bounces forward then back then goes. if I don't get on the gas as quick it smooths out, it seems like the clutch isn't bitting right away. I tried the slip test and the clutch wasn't slipping . Is it me or the car? I think I have a sticking calipr could that be a cause?
hard to tell just by your description, but my guess is it's mostly you and not the car. shifting at high rpms seems to be a problem for newer shifters. it sounds like you may be essentially dropping the clutch when you let it up in the next gear, instead of pausing at the friction zone. also not sure how a sticking caliper (brakes?) will really affect things, unless it's really bad.
jeff6666p
Re: jumpy shifts
Postby jeff6666p » Mon Feb 01, 2016 4:45 am
[/quote]hard to tell just by your description, but my guess is it's mostly you and not the car. shifting at high rpms seems to be a problem for newer shifters. it sounds like you may be essentially dropping the clutch when you let it up in the next gear, instead of pausing at the friction zone. also not sure how a sticking caliper (brakes?) will really affect things, unless it's really bad.[/quote]
I'm not a new shifter and this issue just started about two weeks ago.
Re: jumpy shifts
Postby theholycow » Mon Feb 01, 2016 9:17 pm
jeff6666p wrote:I'm not a new shifter and this issue just started about two weeks ago.
Broken engine mount or transmission mount. Drive up to a curb and park your tires against it, or just set your parking brake if it holds well. Open the hood and peek through the cowl gap at the engine (or use a video camera/etc) while you work the clutch and gas like you're trying and aborting a moderately hard launch. If the engine nudges around a little, ok. If it jumps then it has a broken mount.
Re: jumpy shifts
Postby Rope-Pusher » Mon Feb 01, 2016 11:07 pm
...or if it says: "ARGGHHH! Ow, Ow, Ow, Ow, Ow!"
Then you know you've got a broken mount fur shur.
Users browsing this forum: Google Adsense [Bot] and 7 guests
