Reversing in parking garage
enniroc
Cars: 2015 Nissan Juke SV
Postby enniroc » Thu Aug 13, 2015 4:29 pm
From your lovely FAQ:
It seems to be a general consensus on this forum that people worry about their clutch more than they need to.
True as that may be, I've managed to convince myself that I worry about my clutch too little, and use it too much... especially while squeezing into my cramped parking garage spot.
While reversing into my spot, it seems I can't completely let my foot off the clutch. If I did, the car would move very quickly toward a cement post. I'm hardly touching the gas or brake, just quickly bringing the clutch up to the friction point for a little momentum, then depressing it back to the floor. Lather, rinse, repeat, until my car's where it needs to be.
But maybe there's a better way? Back when I drove stick 10 years ago, I lived out in the sticks. None of this parking garage foolishness.
I've only had my new car for a week. If this is a bad habit, I'd like to be rid of it.
Thanks!
Re: Reversing in parking garage
Postby AHTOXA » Thu Aug 13, 2015 4:37 pm
Perfectly acceptable. In fact, that's the only efficient way to perform delicate maneuvers. I have used this technique for as many years as I've been driving manual (8-9 years, I think?) and have never had issues. That's how most folks on here drive, too.
enniroc
Postby enniroc » Thu Aug 13, 2015 5:32 pm
AHTOXA wrote:Perfectly acceptable. In fact, that's the only efficient way to perform delicate maneuvers. I have used this technique for as many years as I've been driving manual (8-9 years, I think?) and have never had issues. That's how most folks on here drive, too.
Thanks very much! I did what came naturally, but was a bit concerned, since no one ever taught me what to do in that situation.
Postby Rope-Pusher » Thu Aug 13, 2015 7:29 pm
Going fast in Reverse is over-rated. If I were king, all Reverse gears would have a lot more ratio to enable slow speed maneuvers without dithering the clutch engagement.
enniroc
Postby enniroc » Thu Aug 13, 2015 8:08 pm
Rope-Pusher wrote:Going fast in Reverse is over-rated. If I were king, all Reverse gears would have a lot more ratio to enable slow speed maneuvers without dithering the clutch engagement.
Agreed. I don't like the feel of zipping off in reverse. Too hard to react to obstacles, etc. Stick shifts need R-Low and R-High or something.
Postby Rope-Pusher » Thu Aug 13, 2015 10:43 pm
I've shifted my transfer case into low range in order to give myself a "creeper" Reverse ger ratio, but in order to do that, I had to select 4 wheel drive, so it's best to not do this on dry pavement unless you can back up straight (no turning while backing up - I have Part-Time 4WD and it will apply high stresses to the driveline if i turn the vehicle on a high-traction road surface).
Postby Squint » Fri Aug 14, 2015 8:58 am
Yeah, I'll second Tony (AHTOXA). I rarely go in reverse all the way to the point where I'm idling in reverse. There's almost always a game being played with the clutch pedal and the friction point.
Postby tankinbeans » Fri Aug 14, 2015 4:58 pm
There should just be MOAR gears if you want ro go schneller in reverse. That's what big rigs do, richtig?
Postby Rope-Pusher » Fri Aug 14, 2015 11:33 pm
Well, there it is, you've heard it, the Emporer sez "There are too many gears. There are only so many gears the hand can shift in the course of a drive."
I've given up hope of ever having multiple Reverse gear ranges, so if I had ma druthers, I'd druther that the one Reverse gear have a ratio better suited for slowly backing a heavy trailer up a narrow driveway without having to dither the clutch to control the vehicle's speed.
Postby theholycow » Sat Aug 15, 2015 10:38 pm
I don't know, I kinda enjoy cowboying it in Reverse.
But yeah, either that pulse & glide technique or just continual slipping for backing into a spot is fine.
Postby Rope-Pusher » Sat Aug 15, 2015 11:09 pm
theholycow wrote:I don't know, I kinda enjoy cowboying it in Reverse.
Sure, that's all fine for level, paved ground, but try that pushing a trailer up a grassy hill and you'll build up too much heat in the clutch. That's why Dog invented gear ratios, to spare the clutch.
enniroc
Postby enniroc » Sun Aug 16, 2015 8:21 pm
Dog rested a day too early, then. :)
Postby Squint » Mon Aug 17, 2015 10:08 am
:lol: :lol: :lol:
RP, stop trying to back up grassy hills, just turn the car around and Bo Duke that thing.
Postby watkins » Mon Aug 17, 2015 11:45 am
Rope-Pusher wrote:Sure, that's all fine for level, paved ground, but try that pushing a trailer up a grassy hill and you'll build up too much heat in the clutch. That's why Dog invented gear ratios, to spare the clutch.
Been there, done that. Very not fun.
enniroc
Postby enniroc » Sat Aug 22, 2015 6:20 am
Oh lord - I hope I *never* have to do this.
