please critique what I'm doing
DrJerryrigger
Cars: trixy
Post by DrJerryrigger »
Geetings,
So I haven't been driving stick for long, but first learned to drive on one, so I've been frustrated by the lack of control for many years now. So;
The car '04 matrix, 1zz-fe and a w59 (1.8l straight four and a 5speed).
Mostly I just drive to work, and back 7 miles each way. Two stop signs, two lights one two right hand turns and one left....and the opposite on the way back (what's the opposite of a light?) It's mostly 30 & 35 zones and a little bit of 25 when I'm almost there (FYI I drive 5 over like everyone else.... I mean my speedometer is off, in MA it can 9mph off legally). I also drive a mile or so to get lunch, often more "city driving" at that time of day. I end up driving on the interstate and some 45-55 mph highways a little on weekends.
So how I drive; I shift at about 2800rpm and try to give the throttle 80% (so I'm getting up to speed rather quickly) then it put it fifth. So I usually don't hit fourth at all. In 25 zones I often go from second to fifth. The thing that confuses me is; fifth feels right for maintaining 30 on flat ground, where is the gear for 40 or 50?
Re: please critique what I'm doing
DrJerryrigger wrote:Geetings,
They left it on the shelf when they built your trans?
It was an extra-cost option?
They didn't have one at the time that fit underhood without bumping the frame rail?
It would have required another round of certification for a very small sales volume?
It would have required a dual-mass flywheel to reduce the Neutral rattle?
They would have had to tool up a new shifter, shift knob and shift boot?
There wasn't enough room between the driver's and passenger's knee apparati for an extra shift plane?
They couldn't bear the thought of using a lift ring or push-down to allow selection of Reverse gear?
cwat89
Post by cwat89 »
^^^ :lol:
1988 Chevy S10 M5
I will never get rid of this truck!
2006 Chevy Silverado LT3 A4
DrJerryrigger wrote:So how I drive; I shift at about 2800rpm and try to give the throttle 80% (so I'm getting up to speed rather quickly) then it put it fifth. So I usually don't hit fourth at all. In 25 zones I often go from second to fifth. The thing that confuses me is; fifth feels right for maintaining 30 on flat ground, where is the gear for 40 or 50?
Is 2800 necessary? I looked up that engine and it's no torque beast so maybe it is necessary, but it's worth a critical look.
I feel the same way about high gear, or lack thereof, in many manuals. In my 2008 VW I was in 5th at the same speeds you describe. I wanted 6th, 7th, 8th, 9th, 10th, 11th, and 12th gear to get up to 70 without unnecessary buzzing waste.
In that car I experimented with skip-shifting like you do but I ended up using every gear. It was rapidfire shifting. I'd wait at a red light, it would turn green and I'd be in 4th by the time I was under the light. Launch, slap clutch pedal to the floor/pop the accelerator pedal/flick shifter with a "thunk" then the accelerator made a "thack" sound as it hit the floor (wideband O2 means I didn't need to pull my punches to avoid open loop/enrichment) and the clutch pedal got dumped, a moment later it's slap/pop/flickthunk/thack/dump, repeat, repeat. I beat the everliving hell out of the EPA estimates in that car and had a lot of fun doing it without holding up traffic (which only happened when I reached the speed limit -- I cannot risk the ticket, I insure too many vehicles to have my rates get jacked).
Cars: '17 CX-5 GT
Post by potownrob »
it's gonna take you a while to get things down good driving as little as it sounds like you do. i recommend extending your commute to driving a few miles extra, even if it's just driving in a circle around your town. i also recommend practicing shifting through all the gears, at least for now, to get good at normal shifting and learn the characteristics of each gear. as for the 5th gear question, it might seem like some sort of black magic, but 5th gear can be good for a wide range of speeds. Being able to use 5th gear at 30 mph and 90 mph is a good trait. I am aware the older Matrix is not the quickest car out there, but still to be able to use 5th gear at 30 mph around town and also get decent mpg at higher speeds is not something to complain about. IIRC, the model with the 6 speed had the high output engine that you had to work the gears to accelerate (torque didn't come on til higher rpms), so the 5 speed with the lower powered engine (with better lowend torque) was probably not as fun for the spirited driver, but it's more practical in real world driving.
DrJerryrigger
Cars: trixy
2800 is not needed, most situations I could keep it under 1500, heck I could probably keep in under 900 if no one is behind me.
I might be making this up, but I thought I read somewhere that fuel usage to power output (at or need WOT) is best at the RPMs that give the best tourqe (often about 4000rpm for gasoline engines).
As to my shifting system; I feel using all the gears leaves me not giving any power for too much time. If I'm using nearly WOT I need to fully close it for nearly a second before disengaging the clutch so the engine doesn't rev up, which would take more time to compensate for.
DrJerryrigger
Cars: trixy
I should mention I'm getting low 30'sMPG. Really rather good for all the short trips.
Cars: '17 CX-5 GT
Post by potownrob »
DrJerryrigger wrote:2800 is not needed, most situations I could keep it under 1500, heck I could probably keep in under 900 if no one is behind me.
you need to practice driving normally (i.e. shifting through each gear) to learn to do it smoothly; skip shifting early on is just keeping you from figuring out the basics. with the part about 2800 rpms etc., if you're talking about launching at 2800 rpms (as in revving up to 2800 when letting out the clutch in 1st to start moving), that is too high, even on a hill. try to launch at 1500 rpms or lower, and eventually you will be able to comfortably launch around 1k rpms or so.
Cars: '17 CX-5 GT
Post by potownrob »
DrJerryrigger wrote:I should mention I'm getting low 30'sMPG. Really rather good for all the short trips.
that is very good, especially for around town short trip driving.
DrJerryrigger
Cars: trixy
Oh god no, I launch at 900-1200. Still have some work to do on making that second nature, but it's very smooth 90% of the time. 2800(+or- 400) is when I have been up shifting. But working with that system I'm up to speed in third, so I just go to fifth (I always use fourth when getting up to speed on faster roads).
The "black magic" of fifth has a lot to do with aerodynamic. Air drag increases with a cube of your speed, so you need a lot more power to push through. So the gear I want for going 50 would probably be too high for driving 70, customers would be confused about down shifting to go faster...so no extra 3mpg for me.
Cars: '17 CX-5 GT
Post by potownrob »
DrJerryrigger wrote:Oh god no, I launch at 900-1200. Still have some work to do on making that second nature, but it's very smooth 90% of the time. 2800(+or- 400) is when I have been up shifting. But working with that system I'm up to speed in third, so I just go to fifth (I always use fourth when getting up to speed on faster roads).
ok, now your system sounds a little more normal. try shifting a little sooner (at lower rpms) and see how it feels.
Post by tankinbeans »
4000 rpm is better...
It just is. :mrgreen:
Clifford sees it regularly while still returning fantastic mileage. The last fill was 36.2 mixed.
18 Mazda3 iSport
mtheis
Cars: 07 Corolla, 76 Celica
Post by mtheis »
DrJerryrigger wrote:The car '04 matrix, 1zz-fe and a w59 (1.8l straight four and a 5speed).
Sorry to nitpick, but the w59 is a truck transmission. Did you mean c59?
2007 Corolla
2017 Cannondale Quick 3
1995 Tercel
1976 Celica GT
Unofficial SS.com IRC Server
Official lurker
Power output per unit of fuel at or near WOT is better than at part throttle. Do that at peak torque RPM and you're making a ton of energy out of a ton of fuel. If you actually need to make that much energy out of fuel then it would be most efficient to make it that way, but if you don't then it is a huge waste.
For normal driving on the road, the most efficient choice is to open the throttle as much as possible without going open loop*, and keep RPM as low as possible while producing the desired level of acceleration.
*: Likely 50-80% in most cars, but 100% in new cars with wideband O2 sensors, and who knows what in a car with narrowband but drive-by-wire.
Side note: Many people think that torque peak RPM is a magical RPM that, even when not making peak torque, is more efficient. That's generally untrue.
DrJerryrigger
Cars: trixy
That is true. My truck has a W4? in it, I got confused.
