handbrake issues
wannabe
Cars: NONE - take the bus
handbrake issues
Post by wannabe »
background:
when i got this car from grandpa the handbrake didn't work. I had a friend work on it and it works now, if only to hold the car whenits off on a hill. which is fine.
now the car slips on hills (read: driveways) and i've had it slip as i was getting Back INTO the car after it sitting there overnight. driveway has been clear most "winter" of any ice/snow/wetness. theres a grunting/grinding noise that comes from the rear brakes but i don't know if its related, it probably is.
any ideas?
drives me crazy and i get to park on the road most of the time, which isn't bad, its a quiet cul-de-sac and only time i'm in someones way is the snowplow.
Crafting and stuff
Cars: '17 CX-5 GT
Re: handbrake issues
Post by potownrob »
leave it parked in gear (in 1st, 2nd or reverse, and w/ handbrake engaged if on a hill). i had to do this for the whole 5 years i had the maxima - that car's handbrake never held well, even after it was repaired. when i got the 96 accord, it's handbrake worked much better but i still left it in gear to be safe.
Does it feel right when you pull it? Resistance should get progressively tougher until you can't pull it anymore, before you reach the stop at the end of its possible travel. It should feel like someone stronger could pull it one more click.
You could try it on the road at low speed and see if it can slow the car.
Some cars have automatically adjusting parking brakes that require you to back up and use the parking brake to stop the car. Back up at 5mph and yank the brake hard. After a few tries, that may make it auto-adjust. You could also try backing up and slamming on the service brake; some cars adjust that way. You might google for your car to find out a recommended procedure for its brakes.
Could be a loose or broken brake cable. With the brake NOT engaged, it should be taut. Find the cable under the car and follow it back, make sure it is taut everywhere, including the two cables that split off to each wheel.
wannabe
Post by wannabe »
potownrob wrote:leave it parked in gear (in 1st, 2nd or reverse, and w/ handbrake engaged if on a hill). i had to do this for the whole 5 years i had the maxima - that car's handbrake never held well, even after it was repaired. when i got the 96 accord, it's handbrake worked much better but i still left it in gear to be safe.
it is in gear and it still slips!
i was sitting in the back seat cleaning it out yesterday and it was rolling backwards....so i got out cuz i had no foot brake accessibility.
theholycow wrote:Does it feel right when you pull it? Resistance should get progressively tougher until you can't pull it anymore, before you reach the stop at the end of its possible travel. It should feel like someone stronger could pull it one more click.
no, it doesn't feel that way
theholycow wrote: You could try it on the road at low speed and see if it can slow the car.
doesn't do anything on the road....i can drive around town with the handbrake on and go like 40 or whatever.
theholycow wrote: Some cars have automatically adjusting parking brakes that require you to back up and use the parking brake to stop the car. Back up at 5mph and yank the brake hard. After a few tries, that may make it auto-adjust. You could also try backing up and slamming on the service brake; some cars adjust that way. You might google for your car to find out a recommended procedure for its brakes.
good idea. i'll check that if i can get it on the lift at the lab next week
Crafting and stuff
Cars: '19 4RUNNER TRD ORP
Post by AHTOXA »
It ALWAYS feels right when I pull it.
padauk_dust
Cars: '88 Accord, '96 VFR
Post by padauk_dust »
Did you ever get this fixed, Kelly? Hope so.
Many cars have 1 or 2 places the handbrake can be adjusted. If you're feeling up to it you can search for them. One should be near the lever itself and the other near the rear wheels.
'88 Accord DX
'96 VFR750
