I ruled out the fuel system (for the most part) as to why it is a little sluggish, with no hope of getting tire chirps (much less patches of rubber). And as twine-mover had stated, there is a delay - goes away at WOT after hitting about 15-20 mph (I just drove it again today). The car needs a little tuning up though, and a new set of plugs probably wouldn't hurt, neither would a bit of fuel injector cleaner.
My Dad looked at the cooling system (as much as he could see anyway), and we didn't find leaks anywhere, but the car needs a new thermostat. It's stuck open. The heater in the cabin barely blows hot air. I will do what twine-mover said about creating makeshift speed bumps.
Exhaust system on these cars (for '86 anyway) is steel ('87 and up used stainless steel). We aren't for sure positive that there aren't any leaks in the system, BUT, nothing looks damaged.
Windshield wiper system needs something to clean out the pump, the sprayer tubes and the nozzles themselves. Not hard to find a new pump, not sure about nozzles or tubes. The pump might need to be replaced, but it is hard to tell since there is so much…gunk…inside it.
Haven't yet investigated the problem with the windows…the driver's side gets stuck fully lowered and requires a little pulling before it goes back up. The passenger side goes down without problems, but is awfully slow going back up (slower than the driver side). The driver's side lock switch is slow (the passenger side is quick, like it should be). The power mirrors don't work, they either need a new switch or a new motor. They can be adjusted by hand though.
As for the seats, I don't know if both the driver and passenger or just the driver seat is powered. But it works. No problems there.
Got the battery replaced. Car has no issues electrically other than the power mirror system. (So far anyway)
Gauge cluster…I swear it is not the original…and for the most part, the volt gauge is dead. The temp gauge works…sort of..and the oil gauge works fine. There is no tach, and the speedometer and gas gauge seem to work fine (if I make a right turn, the gas goes down towards E, if I make a left turn the opposite happens.)
And while it may seem a pain in the ass, I have yet to see a car (regardless of whether or not it is American, Japanese or European) around here that is in as good of shape or running condition as this Chrysler K-car.
And for the tranny, does anybody have any idea what car would be a good manual tranny donor? I thought maybe a Dodge Neon, but it had a different engine.
I'm still investigating the history of the K-car, among other things in relation to the platform.
'86 LeBaron "Liz"…Questions
Re: '86 LeBaron "Liz"…Questions
LeBarons came with manuals back then. The best donor would be a manual LeBaron (or the rebadges, Dodge Aries or Plymouth Reliant) with a Getrag A525 with all the necessary supporting hardware.
Seriously, that car sounds like a liability, not an asset.
If you think the exhaust system is not leaking then that exhaust smell must be coming from somewhere more expensive.
Windshield washer shouldn't be a problem. The tubes should be standard cheap windshield washer/vacuum hose, they are on GMs. Make sure you can find the right pump cheaply or consider a new system. I couldn't find the pump for my car within my budget; I was afraid of junkyard ones not working for long, but new ones and rebuild kits are expensive. I ended up getting the tank and pump from the S10 which is a better system anyway. Then a few weeks ago I saw a tank and pump on the side of the road that are also a good fit, so now I have a spare (though I haven't tested the pump and I won't need a spare tank and anyway this style pump should be cheap to replace).
Power windows are easy enough to fix. Power mirrors can be ignored.
The cluster thing is worrying, but not the part about the gas gauge moving when you take turns. That's standard gas gauge sender behavior in older cars and in cars with messed up senders. It doesn't matter.
If you think you can have a lasting love for this car and not just a temporary infatuation then it could possibly work...but it sounds like a terrible idea to everybody here.
I agree with the tall man, the quirky man, and the uddered one. Run, just RUN away from it.
Which one?94Corolla5Speed wrote: the quirky man
The quirky man with the quirky car. With a quirky amount of torque steer.watkins wrote:Which one?94Corolla5Speed wrote: the quirky man
Turbo? Manifold? Catalytic Converter? Muffler? Of those things, the CC and the turbo are most expensive. If it comes down to that, IDK what I'll do at that point…depends on whether or not I buy the car.theholycow wrote:Seriously, that car sounds like a liability, not an asset.
The other parts of the car I'm not entirely worried about (well, sort of - at least concerning that one gauge (not the gas) and the windshield cleaning system)…theholycow wrote:
Would seafoaming the car show where the possible leaks are?
Itsa me! Saabario!94Corolla5Speed wrote:The quirky man with the quirky car. With a quirky amount of torque steer.watkins wrote:Which one?94Corolla5Speed wrote: the quirky man
GM seems to have beaten everyone to the punch by using turbos on several models back in the early 1960's.watkins wrote:Saab, and to a lesser part Volvo, perfected the use of turbos in automotive applications before Americans had ever heard of themtheholycow wrote:Out of the frying pan and into the fire?watkins wrote:European cars.
I also wooden say You're-a-peein's perfected them. Turbo technology is still work in progress. Them You're-a-peein's weren't the first to use water-cooled center housings and a lot of other changes/improvements that have come along thru the years.
