hi,
i recently bought an 02 vauxhall vectra elegance 2.2 dti with 115000 on the clock. i took it for a service everything was fine apart from the mechanisc saying he noticed a leak under the car cleaned it but couldnt find the source. i have just noticed now that when the car is idling there is a loud whirring noise from the engine which stops when i depress my clutch. could this be my gearbox could be on its way out? or could it just be a gearbox oil leak? any help would be greatly appreciated
gearbox gone or oil leak
- ihartmacz
Re: gearbox gone or oil leak
Does it whine or make any other noises when you load the transmission to the engine (when driving). I would check the transmission fluid level. It's possible that it's the throughout bearing for the clutch
no it makes no other noises mate and when im driving the gear changes seem nice and smooth
i think my truck does the same thing, but only when its cold so i always assumed it was from the tranny lube not being at operating temperatures. if it goes away when you disengage the clutch then its definitely your gearbox, but if the fluid is fine then the only thing i could recommend is a flush and a fill up
