Project RA24 Celica
noob5,000,000
Cars: 1986 Mazda RX-7 x2
Re: Project RA24 Celica
Postby noob5,000,000 » Tue Apr 02, 2013 10:29 pm
94Corolla5Speed wrote:
noob5,000,000 wrote:Neat!
Yes!
1986 Mazda RX-7 base - Project car, nearly driveable in n/a form, gathering parts for turbo swap
Postby theholycow » Tue Apr 02, 2013 10:35 pm
I can't remember anymore why that picture was posted or why everyone keeps quoting it and not really adding anything, so here's this:
94Corolla5Speed
Postby 94Corolla5Speed » Thu Apr 04, 2013 1:50 am
I'm still baffled by Shadow's post. Cup rocks? No ice?
noob5,000,000
Postby noob5,000,000 » Thu Apr 04, 2013 2:46 am
94Corolla5Speed wrote:I'm still baffled by Shadow's post. Cup rocks? No ice?
Drink with no ice = neat. :P
Sorry for the de-rail, OP :lol:.
Postby Rope-Pusher » Wed May 01, 2013 9:50 pm
mtheis
Cars: 07 Corolla, 76 Celica
Postby mtheis » Sat May 04, 2013 10:53 am
Progress has been slower than expected. It was a waiting game while I acquired better tools to get anything done.
Here's what I've accomplished in the past week:
Port matched the cylinder head and intake manifold.
Acquired an engine hoist and load leveler.
Removed the 22R shortblock from the trunk of the car.
Installed the flywheel.
Installed the clutch. I ended up aligning the clutch with a head bolt. If I ever have to do it again, I'll be using the input shaft from the old transmission.
Prepped the transmission for installation.
Surprisingly, the clutch was centered closely enough to get the transmission attached.
I'm installing the cylinder head today and prepping the car for removal of the old engine and transmission. Tomorrow will (hopefully) be engine swap day. Next steps will be rebuilding the carbs, draining the gas tank, and putting in a battery.
2007 Toyota Corolla
1995 Toyota Tercel
1976 Toyota Celica GT
Unofficial SS.com IRC Server
Official lurker
mtheis
Postby mtheis » Sat May 04, 2013 10:52 pm
I got the cylinder head installed with a great degree of difficulty. There was quite a bit of rust and other crap that had to be removed before I could get the head bolts to turn. The chain on the cam sprocket didn't have enough slack to allow the sprocket to slide on. I ended up lifting the sprocket with a screwdriver and turning the crank back and forth a few times until it fit.
Here it is with the valve cover on.
2007 Toyota Corolla
1995 Toyota Tercel
Official lurker
Postby Shadow » Sun May 05, 2013 7:57 am
Don't want to invest in an engine stand?
mtheis
Postby mtheis » Sun May 05, 2013 9:01 am
It crossed my mind and I may still get one at some point if there was a need to move the engine out of the way or take the oil pan off.
2007 Toyota Corolla
1995 Toyota Tercel
Official lurker
mtheis
Postby mtheis » Sun May 05, 2013 11:40 pm
mtheis wrote:...or take the oil pan off.
I have to swap oil pans. :x
There just isn't enough clearance for the front of the 22R pan to clear the crossmember. Can you see the differences? 22R on the left and 20R on the right.
Both halves of the driveshaft were rusted together and required complete removal to separate them.
Here's the center console and shifter removed.
The car sits a bit higher now. :mrgreen:
This is what happens when you think you're gonna be smart and not drain the transmission before removal and instead attach a bag over the end of it.
2007 Toyota Corolla
1995 Toyota Tercel
Official lurker
Postby theholycow » Mon May 06, 2013 7:05 am
:lol: That failed smartassery with the transmission fluid sounds like something I'd do.
What effects will the shallow oil pan have? Reduced oil change interval and increased oil temperature, I imagine...anything else?
mtheis
Postby mtheis » Mon May 06, 2013 8:05 am
The pans are both the same depth in different places. Oil pickups will probably have to be swapped as well.
2007 Toyota Corolla
1995 Toyota Tercel
Official lurker
Postby Squint » Mon May 06, 2013 12:32 pm
theholycow wrote::lol: That failed smartassery with the transmission fluid sounds like something I'd do.
The real reason we have cats is revealed. Just so we have cat litter handy :lol: :lol:
Postby Shadow » Mon May 06, 2013 8:22 pm
mtheis wrote:This is what happens when you think you're gonna be smart and not drain the transmission before removal and instead attach a bag over the end of it.
Ouch....that's gonna leave a mark! :lol:
That's exactly why I coat my garage floor with an epoxy finish before I stain it will oil.
Postby Rope-Pusher » Wed May 08, 2013 10:34 pm
mtheis wrote:Image
I like the liquid mirror you put under the car. Where did you buy it? I'm gonns get me one for the next time my Jeep is in a car show!
Return to “Members' Cars”
Users browsing this forum: Google [Bot] and 1 guest
