introductory posts SEEM easy...
Leedeth
Re: introductory posts SEEM easy...
Post by Leedeth »
Welcome, and you should try this sometime, a ramdom guy on omegle said that if you stay up 50-60 hours you will hallucinate and the subconscious will tell you what it thinks.
A manual truck driving girl? I wish you much luck around these goons. :lol: Nah, nobody bites (hard).
Anywho, Im the resident Viggen driver and a New England member. North Andover MA and Cranston RI, depending on the day.
Not to go off topic already (yeah right), but Im now curious - New Englanders sound off:
1. watkins
2.
3.
4.
LHOswald
Cars: '99 Civic Hatch w/B16a
Post by LHOswald »
1. watkins
2. LHOswald
3.
4.
5.
Warner
Post by Warner »
Welcome.
sasquatch wrote: Hmm.. I have no idea if I have synchronized transmission. I'll try to find out, I need to get the truck checked out at a mechanic just to make sure it doesn't have any hidden problems anyway, but is there a way I could tell on my own if it is synchronized?
If you can get behind the steering wheel without having to do a back-flip, then you've got a synchronized transmixer. (Without functioning synchronizers, you would need to double-clutch to shift from one gear to another while rolling down the road). I would think that in your Fraud that for sure Reverse and maybe 1st gear are not synchronized. What do you have, a 3-speed or a 4-speed? Do you have a "granny-gear" 1st gear? Shifter on the tree or on the floor?
sasquatch
Cars: 1972 Ford F250
Post by sasquatch »
It is a four speed. I was wondering about first gear in my truck, which is very short. The truck would rather just start off in second gear it seems, and I'm unsure if this is common in older trucks or what...
Thanks everyone for the advice and welcomes :D
Tups
Post by Tups »
sasquatch wrote:It is a four speed. I was wondering about first gear in my truck, which is very short. The truck would rather just start off in second gear it seems, and I'm unsure if this is common in older trucks or what...
As far as I know, launching on 2nd is quite common in bigger trucks, but then again they usually have more gears as well...
2007 Ford Focus ST225
1982 Ford Escort Mk3
sasquatch wrote:As far as where I live, when I'm not traveling for work I usually live right in Boston
Wow. I wouldn't want to drive that truck living in Boston. Well, really, I wouldn't want to drive anything in there daily. I'm guessing you don't drive it around town when you're home, though...
I'm going on a trip from New Mexico to Louisiana soon, so I'm asking everyone all the questions I can.
Another wow. You're new to driving stick and you're embarking on long-distance traveling with a 38 year old stick shift vehicle...very cool! Image
AFAIK, a lot of older full-size trucks had an ultra-low crawl gear for offroad/heavy work/trailer towing that is not necessary in daily driving.
LHOswald wrote:1. watkins
2. LHOswald
3. Divine/perforated bovine
4.
5.
Most likely uses the NP435 transmixer.
http://www.novak-adapt.com/knowledge/np435.htm
Rope-Pusher wrote:Most likely uses the NP435 transmixer.
From that link:
The NP435 enjoys a very low compound gear at 6.68:1 and as such it is a popular choice for those wanting a very low crawling gear.
From http://classicbroncos.com/tranny-np435. ... te]There's no speed shifting with this tranny. These are truck transmissions and you know it when you shift. First and reverse are non-synchronized.[/quote]That answers a couple questions.
FDSpirit
Cars: 2000 Honda Civic Si
Post by FDSpirit »
2. LHOswald
4. FDSpirit
5.
Warner
Post by Warner »
FDSpirit wrote:
2. LHOswald
4. FDSpirit
5.
Imposter!
From that link:
That answers a couple questions.[/quote]
Also, if you look at the pics you can see that it has a long shift lever coming out of the top of the trans. This is necessary to place the shift knob where the driver can reach it and with bends to avoid hitting the seat or instrument panel. Places a lot of leverage on the select finger inside the tranny. UPS in this area cut the lever shorter to avoid drivers snapping off the select finger, but that meant that drivers had to bend toward the lever for many or mosts shifts. Not an elegant solution.
FDSpirit
Post by FDSpirit »
Warner wrote: Imposter!
Shhh! :lol:
sasquatch
Post by sasquatch »
Haha, thanks! I'm definitely some sort of mentally ill to be jumping in like that, but there you go. I will try it out on a trip to Roswell this coming week I believe, which should give me an idea of how it'll do long distance.
It's really, really good to know that 1st and Reverse are most likely not synchronized, and it makes a lot of sense with how my car's been reacting, especially reverse, when shifting. I suppose I should start practicing my double clutch skills? (Although I don't know how it'd affect reverse, since I usually would only reverse in a 3 point turn situation usually..)
The longest I've stayed up would probably be around 54 hours, and by hour 40 I was hallucinating that the core of an apple I ate was moving on its own. Maybe my subconscious is a little cryptic :) ?
