"Yadda, yadda, yadda - and now the impotent stuff:
...we’re making it available with an optional automatic transmission, to appeal to a wider group of sports car wannabe drivers.”
The ZL1 will be offered with either a six-speed manual or automatic transmission. The Tremec TR-6060 “MG9” manual features 30 percent more torque capacity than in the Camaro SS. The higher torque capacity results from a strengthened output shaft, high-strength rear housing, and additional roller bearing. The MG9 has also been tuned for improved shift feel, with a dual-mass flywheel, twin-disc clutch, and triple synchros for smooth, precise shifts.
Similarly, the Hydra-Matic 6L90 automatic has been strengthened to handle the torque and horsepower produced by the 6.2L supercharged small block. The 6L90 features a strengthened input gearset with two additional pinion gears, additional clutch plate, and a strengthened output shaft and gearset. To make the ZL1 perform equally well on street and track, the 6L90 features three distinct drive modes:
Drive: The shift pattern is calibrated for optimal fuel economy, including second-gear starts, while the shift feel is tuned for a smooth driving experience. Engaging the tap-shift feature on the steering wheel or shift lever engages temporary manual mode.
Sport: The shift pattern is calibrated for more aggressing driving, including first-gear starts for maximum performance. The shift feel is also more aggressive, with a performance algorithm that holds the transmission in lower gears during aggressive driving.
Manual: Here, the 6L90 offers the driver true manual control, with no automatic up shifts, and staged upshifts for incredibly fast shifts and maximum performance.
Other track-ready features of the ZL1 include:
An engine-oil cooler, identical to the system on the Corvette ZR1. The integral liquid-to-liquid system is so effective that both the manual and automatic transmissions are deemed to be fully track-capable with the standard factory-installed cooling package.
A rear-differential cooler, which pumps transmission fluid to a heat exchanger, reduces temperatures in the differential by more than 37.8 C (Double it for approximate "real" degrees)
_________________ '08 Jeep Liberty 6-Speed MT - "Last of the Mohicans"
MILFORD, MI – General Motors expects the powertrain mix on the high-performance ’12 Chevrolet Camaro ZL-1 to weigh upwards of 50% in favor of the automatic transmission, buoyed by evolving customer preferences.
“There are a lot of people out there who, as they age, do not want a third leg,” says John Fitzpatrick, marketing manager for the Chevy Camaro and Corvette.
“And then you have younger people who have never been exposed to a manual transmission,” he tells WardsAuto during an event at GM’s proving grounds to detail the ZL-1’s hotly anticipated specifications.
According to WardsAuto data, 89% of model-year ’10 passenger cars in the U.S. were equipped with automatic transmissions, up slightly from 88.3% a decade earlier.
Other performance cars under Fitzpatrick’s watch also lean toward the 6-speed automatic, including the Camaro SS, with 70% of buyers skipping the third pedal and 65% of base Corvette owners doing the same.
“It’s sad,” he admits.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
