bk7794 wrote:I've got a funny issue. The only thing I can guess is that it has something to do with the pitch of the car. When I first start my car in the morning. I go up a slight grade and both the 91 and 00 shift fine into 2nd. Then I come to the end of my street, when I turn right I go downhill, both of the cars definitely do feel notchy only when I go down that hill in the cold weather. Must be the oil sloshing to one side of the transmission. Kind of a funny issue.
Yes, trans oiling can change as a function of the pitch of the vehicle. Synchronizers operate differently when the amount of lube on them changes. Lowest point in transverse-powertrain FWD Transaxle is typically below the differential (Toward the rear of vehicle on most of these vehicles).
When driving nose up, more trans fluid tends to stay in the back.
When driving nose-down, fluid level is higher in the front of the trans.
Transmission is lubricated by oil spray being flung off of gears (including the differential ring gear), not by a pump.
When the trans is tilted, the pattern of the oil spray off the gears changes.
Oh, and cold fluid, it gets sprayed around less than warm fluid, but it's also more difficult for the synchronizer ring to clear it off the cone on the speed gear.
High RPM clutch drag
Re: High RPM clutch drag
- Cars: 2012 Chevy Sonic Turbo
If you've got a cable clutch you probably need to adjust it. Your problem that you described before is very much a clutch disengagement issue.bk7794 wrote:I've got a funny issue. The only thing I can guess is that it has something to do with the pitch of the car. When I first start my car in the morning. I go up a slight grade and both the 91 and 00 shift fine into 2nd. Then I come to the end of my street, when I turn right I go downhill, both of the cars definitely do feel notchy only when I go down that hill in the cold weather. Must be the oil sloshing to one side of the transmission. Kind of a funny issue.
Have you heard of something called shift blocking?Shadow wrote:A "notchy" shift from 1st gear to 2nd gear simply means that the sychronizer isn't up to the job of, well, synchronizing shaft speeds. Why that happens isn't always easily apparent. In some cases, cold temps magnify the issue, mostly because of the viscosity of the gear lube in the box. In other cases, it could be a case of a worn synchro itself. And in other cases, the synchro may be in good condition, but it's just not designed robust enough to effectively do its job properly under all circumstances. Either way, no driver should be forced to compensate by purposely shifting at a specific RPM to avoid a notchy shift. Sure, that may be an easy way to minimize the issue, but a better option is to correct the issue in the first place so you have the freedom and ability to shift at any RPM without getting a notchy shift in the first place.SonicHKS wrote:
Time to go off-topic from your problem. 1st-2nd is a tricky shift for a lot of cars. The Sonic forums have a lot of people who complain about it. Supposedly, the Sonic has a notchy 2nd gear that doesn't like to engage with a high-rpm shift from 1st. Me....I've never had a problem with it. You just have to realize, that's the biggest gap between gears, and you have to give the synchro an extra split second to do its thing. So to me, shifting my Sonic to 2nd at high rpm is actually smoother than low-RPM. At low-rpm its more complicated, a combination of the big gap between gears and the right speed/timing required to get it right. High-RPM its just a fast shift with an extra split second waiting at the gate for 2nd gear.
One thing that can help a great deal (and sometimes completely eliminate notchy shifts) is a simple swap of the gear lube. For example, Redline makes some great products that have been known to completely eliminate notchy shifts. You should try them yourself and maybe then you won't have to run your engine to high RPM in 1st gear all the time to get a smooth shift into 2nd. And you won't have to delay your shift either. I don't want the gearbox telling me how to drive the car; I want to tell the gearbox how I'm going to drive the car. That's the whole point in driving a manual transmission car in the first place.
http://en.wikipedia.org/wiki/Shift_blocking
I wondered what your opinion was. This is actually brand new to me.
Keep in mind the high engagement is on a cable clutch. One adjustment and you can move the engagement point down. Then again you get lousy pedal feel. But when you're trying to get as much life out of the clutch as possible, who cares. I'm wondering about the clutch in my 00. With it being a used car I have no idea on how the car was treated, the clutch and all that. I must admit I'm sure the transmission wasn't treated all too well with Reverse having some problems engaging. It all works now and I just like having the peace of mind knowing I can get into 2nd if I am in a hurry.SonicHKS wrote:lol @ all the noobs in this thread. bk's problem is actually very simple.
bk, your clutch isn't fully disengaging. Its like you're partially shifting without using the clutch. The problem is worst shifting to 2nd at high rpm in 1st because that has the biggest gap between gears of any shift in that car. Also, if you're trying to shift fast it'll make it worse as you're not rev-matching the shift. Waiting at the gate for 2nd and going in at the right time should revmatch it and have it shift smoothly. You're not having a problem with it in the other gears because in those gears you shift slow enough for it to just revmatch on its own with your normal timing.
Also, another thing. What you're referring to as "clutch engagement" isn't what you think it is. You're referring to it as a point. Its not a point, its an area in the clutch pedal's range of motion. And that area/range will increase as your clutch wears. If the clutch pedal has a range of motion of about 12", ideally you'd want it to grab and fully hookup over an area of an inch or two, and starting at least an inch or 2 off the floor to have some breathing room for clutch disengagement. If your clutch starts to grab "beneath the floor" like you've said, and doesn't fully hook up til high in pedal travel, you're wearing it pretty bad. If anything you've got a glazed clutch, if not one that's on its way out. For one thing the 'not fully disengaging' problem you're having isn't good for a clutch.
And I'll just say this. There's 2 types of drivers. Those who respect their cars, and those who don't. To me, I care about my car and would want it to last the rest of my life if it could. I don't demand too much of it, I work with it. This is something you learn from driving older cars, where abusing it and forcing it to drive a certain way could leave you stranded. Now, the other type, consider cars to be disposable and when it breaks they'll just buy another one . I have no respect for people like that.
- Cars: 2014 ford focus should 5s
My saturn did this and it eventually through a diff pin.....sad day maybe try changing the fluid to some high quality stuff? Maybe itll help?
